--->Power brakes vaccum line - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-12-2004, 10:42 AM Thread Starter
I hooked up a used (but apparently working) power brake booster /bracket to my 82CJ7. I bought a rebuilt master cylinder, and used the tri-county gear brake rod.
The brakes DO NOT seem to be any better than before with manual brakes. Before I replace the booster ($$), I want to know if anyone can see a problem with my vacuum line hookup (PICTURE) or see any other problems. I hooked manifold vacuum to the booster basically.
pnut is offline
post #2 of (permalink) Old 03-12-2004, 10:58 AM
thorjeep's Avatar
Re: --->Power brakes vaccum line
You bench-bleed the MC first of course..
thorjeep is offline
post #3 of (permalink) Old 03-12-2004, 11:30 AM
Official Historian
WILL's Avatar
It should be hooked to manifold vacuum. I don't think you'll get enough from a carb port.
WILL is offline
post #4 of (permalink) Old 03-12-2004, 12:31 PM
Is that a stock cj booster? The cj boosters aren't very good to start. They are a single diaphram which is why most people upgrade to a double from a chevy.
post #5 of (permalink) Old 03-12-2004, 12:36 PM Thread Starter
I know I have seen the past posts regarding using a double diaphram booster, but thos posts say to use a different bracket.
Will the GM dual diaphram booster (for example from a 1990 Caprice) mount up to the stock CJ bracket?
I would be VERY surprised however if there was not something wrong with my setup or a non-functional part. The braking is almost equal to manual. I am not expecting tippie toe braking, but I at least expected SOME improvement, which I don't see so far.
Also, thanks for the tip about carb vacuum, I will attach to manifold vac and try that, I didn't think about that.
pnut is offline
post #6 of (permalink) Old 03-12-2004, 12:45 PM
My cj is on 35s and I have the gm booster out of a 85 suburban. It didn't have the correct bracket to work but I fixed to so that it would mount to the stock bracket as a short term fix. Not really sure of which model cars to get it from.
I have some other issues that make my vacuum a problem. But with high rpms I can lock up the tires...
post #7 of (permalink) Old 03-12-2004, 02:05 PM
Official Historian
WILL's Avatar
I've read that the dual diaphram from an S truck works well.
WILL is offline
post #8 of (permalink) Old 03-12-2004, 03:05 PM Thread Starter
Any pictures of the 85 Suburban booster setup?
pnut is offline
post #9 of (permalink) Old 03-12-2004, 08:43 PM
OlllllllOCJ's Avatar
This mess gets my vote for most disjointed thread in weeks. Care to start over ?
Or did you just take Will's advise and it now works? It should be manifold vacuum.
Ramble on !
OlllllllOCJ is offline
post #10 of (permalink) Old 03-12-2004, 11:16 PM
Yes, bring the vac directly off the manifold. I am using a Dual booster I pulled from a mid 80's Cadillac; it required a little tweaking on my stock mounting bracket, but it's worked fine for two years.
CJ money pit is offline
