nv3550 vs. nv4500 vs. WCt5 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-08-2004, 09:13 AM Thread Starter
Am planning a tranny swap to replace my stock t5 later this year. Also will be installing a 5.0 EFI.
I was planning to build a WC t5 so that I could keep the tailshaft housing that I have and not have to buy any adapters. But, the apparent weakness of the t5's has me wondering...
Is a NV3550 that much stronger than the t5? They're both aluminum cases, and I believe they both have about the same torque rating (~300ft.lbs.) Also, I think I can bolt it to my d300 with just a clocking ring. What's involved $$$ to bolt it to a 302?
I know the daddy would be the 4500, but the cost has me balking. I could be talked into it though....
Thanks, sorry for the length.
highmtnjeepn is offline
post #2 of (permalink) Old 03-08-2004, 09:45 AM
Mike86CJ7's Avatar
Re: nv3550 vs. nv4500 vs. WCt5
Well, you can look at it this way. The NV4500 will probably be the last manual trans you ever have to buy. Consider how long you plan on keeping your rig, and spread the price over that time period. It mght be more cost effective than it first appears.
Mike86CJ7 is offline
post #3 of (permalink) Old 03-08-2004, 12:21 PM
general420's Avatar
The 4500 is the king of the block, and if you find the right Dodge 4WD version, a clocking ring will work to bolt it to your D300 (do a search, there was a couple good postings on it). The 3550 is till a much sturdier unit than the T-5, and would be cheaper. As for the WC t-5, you know what they say, if you polish a turd, you have a good looking turd. The t-5's weakness is in the construction of the case, which is not changed in the WC version, just beefed up guts. Just my .02
general420 is offline
post #4 of (permalink) Old 03-08-2004, 04:03 PM
Wouldn't a T-18 be the best and cheepest manual tranny to attach to a Ford 302? The other three trannys you listed would cost a lot in adapters with a 302. You give up the overdrive with the T-18 though.
I have a W/C T-5 and am very pleased with it. But I would not use it with a V-8.
[img]images/graemlins/scs.gif[/img]
flintstone is offline
post #5 of (permalink) Old 03-13-2004, 06:23 PM Thread Starter
Back to this topic after a while.....
Is the 3550 that much stronger than the t5?
I don't mean to beat this subject to death, but keeping a t5 derivative would be easier than the 3550 if they're about the same.
Am I going to have to buy an adapter to bolt the 3550 to a sbf? Are any stock bellhousings a fit? I am assuming that the 3550 is external slave.
Gotta have the od. 4.56 is not highway friendly at 1:1
post #6 of (permalink) Old 03-13-2004, 07:17 PM
gigolo's Avatar
If the budget allows for it, I'd go for the 4500. If you're going to drop the dough on a 3550, b/h, clutch parts, etc, then you might as well put out a little more. It's like insurance that you won't have to again, even if you decide to put big block in. A 5.61 first is great, and like Mike said, it will probably last you forever. I'm a bit of a 3550 hater, since I had one of the early 2000 tj defects. But, if I hadn't I probably wouldn't have put a 4500 in mine. I knew it was a defect, and probably could have fought the dealer tooth and nail to get it replaced, but I decided to go for what would only have to be done once. And it's been a great tranny, as long as you can handle some not so pleasant rattling noises from time to time.
gigolo is offline
post #7 of (permalink) Old 03-13-2004, 08:53 PM
Dirt Dog's Avatar
IF you can afford it.......go for the 4500.
I would if I could. (end of story)
The WC T-5 isn't bad but not bulletproof and lacks the granny. The 3550 is a "smidge" better. The T18 is awesome in strength, but lacking the driveability of the overdrive. (with deep gears)
So it boils back down to what do you want............and what can you afford?
I go to sleep at night dreaming about the NV4500. [img]images/graemlins/tongue.gif[/img]
Dirt Dog is offline
post #8 of (permalink) Old 03-15-2004, 12:04 AM
If you go with the NV3550 get a newer one. Older ones popped out of gear sometimes. The NV in my Rubicon makes a lot of noise in neutral. But I believe this is natural. They also require some $$$$ special tranny fluid.
As stated above the nv4500 is what most of the Big Dodge trucks come with. It is a bulletproof tranny as it WILL be you last to buy.
87Warrior is offline
