By-passing the computer? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-06-2004, 02:29 PM Thread Starter
Journeyman
Is it possible to by-pass the computer and run the distributor right off of the ignition module? I have an '88 YJ, weber carb, TFI upgrade, and no emissions stuff except the 02 sensor(mainly for my air/fuel ratio gauge). If keeping the computer will help the Jeep run its best and keeping it is the best route, than I'll keep it. But I don't at all mind doing the work to get it out of there. I thought it was there for that stepper motored carter carb. And with the weber, I can't see a reason for keeping it besides if it does something for my distributor that my module can't do alone. Opinions, please? Thanks
Tim [img]images/graemlins/crazy.gif[/img]
USMCYJ is offline
post #2 of (permalink) Old 03-06-2004, 02:32 PM
Journeyman
scrapiron's Avatar
Re: By-passing the computer?
Just do a search on "nutter bypass". Really is a easy mod to do. I felt improvement in mine right a way.
scrapiron is offline
post #3 of (permalink) Old 03-06-2004, 02:43 PM Thread Starter
Journeyman
I could be wrong but the Nutter by-pass won't affect me because I have a non-computer controlled carb. Will it affect the ignition?
USMCYJ is offline
post #4 of (permalink) Old 03-06-2004, 03:01 PM Thread Starter
Journeyman
LEVE wrote in a post on google,
1. Yes,
2. Simply identify the wiring from:
The Distributor
The Igniton Module.
The Sensors to the ECM
3. Once identified,
4. All wiring to the ECM can be removed from the wiring harness.
5. Then the ECM and mass of wriing can be removed.
6. There should be more than enough OEM wiring,
7. To do the bypass without running new wiring.
that is his exact post. Can anyone explain how to identify the wiring and what to look for? I don't want to mess it all up and end up with more problems. I have confidence that I can do it I just need a push in the right direction. Thanks
Tim
USMCYJ is offline
post #5 of (permalink) Old 03-06-2004, 05:36 PM
cj7ted
As LEVE wrote. That's what I did on my 83 CJ7.
