-   -   The TH350 is making trouble! (https://forums.off-road.com/jeep-short-wheelbase/188308-th350-making-trouble.html)
cj5with454bb 03-05-2004 03:06 AM
When I put the TH350 in "P", it seems like the lever on the TH350 gets stuck. When I want to go from "P" to "D", the lever won't move at all. I have to use force to get it "unstuck". Any ideas to what the problem is here?
Olin18 03-05-2004 06:50 AM
Re: The TH350 is making trouble!
It sounds like a linkage problem more than a transmission problem.
What kind of linkage do you have. Do you have a conversion shift kit on it. If so you may have a kink in the cable.
Provide us with just a little more info about the problem
When in drive or "R" Does the trans over rev, or slip?
WILL 03-05-2004 08:06 AM
Does it do it if you set the parking brake first and then shift into and out of park? It's probably just the pressure on the parking prawl from holding the jeep still.
cj5with454bb 03-05-2004 09:36 AM
I took the linkage from a Mazda 626. Don't know if that model is available over there, but here in Denmark, Scandinavia, it is very common. The linkage is floor mounted and operated by cable.
If I go in and out of P, there is no trouble
cj5with454bb 03-05-2004 09:38 AM
BTW the trans doesn't slip or rev. It's newly rebuild and works otherwise perfect
