New steering shaft w/pics Heavy Duty. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-27-2004, 09:23 PM Thread Starter
pontiac58's Avatar
Been working on the CJ for the last two or so months. It all started with a new exhaust system. Well still no new exhaust, but in the process i have done some other things. When i pulled the steering shaft and drivers side fender to drill a broken manifold bolt. I found my steering shaft was getting tired. About 2 years ago, i took three stock steering shafts and made one really tight one. Well it didnt last long. I was going to get a borgeson shaft, but i found something better.
I have enough parts to build more and ill put a post up on the F/S post.
Heres the pics.
Stock lower joint with new upper.
Stock upper with new lower and a borgenson joint and shaft.
Another shot of all three.
You can see how easy the shaft will move in and out and it will be much easier to remove if you have too. Everything is greasable, joints, and slider. The shaft is bigger then a stock front driveshaft. I dont think, ill ever where these out.
pontiac58 is offline
post #2 of (permalink) Old 02-28-2004, 11:37 AM
Re: New steering shaft w/pics Heavy Duty.
Those look like the same Spicer yokes I used for the gearbox and steering column. I used a slip yoke on one end of the shaft for adjustability, and grafted them onto a stock shaft. That way I maintained the same collapse range of the stock shaft, and for my use the stock shaft is plenty strong.
How much will your shaft compress? If that's not getting too personal. [img]images/graemlins/blush.gif[/img]
Jim_Lou is offline
post #3 of (permalink) Old 02-28-2004, 05:37 PM Thread Starter
pontiac58's Avatar
In case of a wreck it can collapse all the way too the yoke. The spline section is welded onto the tube. For flex of everything moving during a wheeling trip, the splines can move 4 to 5 inches easily and with leaving at least half of the splines still intact. Its a kick butt setup. I got it on today and will have to add a pic later on.
post #4 of (permalink) Old 02-28-2004, 08:16 PM
jeepgod's Avatar
looks good jim.. but how is the clearance around that thing? i know mine ran pretty close to the exhaust and the frame...
jeepgod is offline
post #5 of (permalink) Old 02-28-2004, 08:31 PM Thread Starter
pontiac58's Avatar
The lower section is really no closer to the frame as the stock unit, because of it being just about the same size. And clearance for the manifolds isnt a issue at all. I left my camera at the shop or id have install pics up.
glad to see you around Pat.
post #6 of (permalink) Old 02-28-2004, 09:45 PM
Dirt Dog's Avatar
Nice looking piece Jim. Good work.
Dirt Dog is offline
post #7 of (permalink) Old 02-29-2004, 06:31 AM
brendan
Do you have the spicer PN on the upper joint? Mine is shacked, and if I'm going to replace it, might as well do it once.
post #8 of (permalink) Old 02-29-2004, 02:14 PM Thread Starter
pontiac58's Avatar
Nope dont have a clue on the part numbers. Plus there are two different joints. So it would depend on what you have now. Just take it out, measure it and order one that way. Thats how i would do it.
post #9 of (permalink) Old 03-01-2004, 09:13 AM
Jim,
I want one.....
post #10 of (permalink) Old 03-01-2004, 11:23 AM
That thing is bigger than a lot of drive shafts that come on Cute utes.....
Great upgrade.! [img]images/graemlins/RockOn.gif[/img]
Olin18 is offline
