rear axle on the front WTF - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-11-2004, 08:40 AM Thread Starter
ok i was reading in JU this morning and i say a 53' flatfender jeep with ford 9's front and rear.......i know they use the 9" center with D60 knuckles and stuff....but what is the advantage of doing this then just running a D60 upfront.............plus john sumner(?) from WMS i think is running 14 bolts front and rear, again what is the advantage to doing this when you use the D60 outers and stuff [img]images/graemlins/confused.gif[/img]
help the stupid
john [img]images/graemlins/givemebeer.gif[/img]
WHTTRASH is offline
post #2 of (permalink) Old 02-11-2004, 08:51 AM
Official Historian
WILL's Avatar
Re: rear axle on the front WTF
9" is easier to set up gears on, 14 bolt has cheap detroit lockers.
WILL is offline
post #3 of (permalink) Old 02-11-2004, 08:53 AM
Pooh-Bah
uglyjeepoffroad's Avatar
Don't they flip the centersection when running up front? This would give a very high pinion.
Maybe there is more clearance over a d60 centersection?
uglyjeepoffroad is offline
post #4 of (permalink) Old 02-11-2004, 10:59 AM
The stock 9" housing offers a slight ground clearance advantage over a stock d60 housing,,,,,,But a shaved d60 factory housing can have the same clearance,,,,,,,and a aftermaket d60 housing can have better clearance then a stock 9".
The guys at Wagoner run HUGE tires and require alot more axle to handle them. Casey told me, they are also using Rockwell knuckles and outter on steering 14 bolt's.
W.C. is offline
post #5 of (permalink) Old 02-11-2004, 11:56 AM Thread Starter
ok i see what your saying [img]images/graemlins/wink.gif[/img] but would it not be cheaper to just shave a d60 then to the 9"/d60 deal with custom axle shafts that you cant get at a junkyard or off the shelf item?????
or just do rockwelles then having to make custom shafts for the 14 bolt/rockwell combo?????
hhhuuummmmm maybe i can save up some cash and do a d60 center with volvo portal ends.....nnaaaaaaaaa to much work and not enough wheeling [img]images/graemlins/grin.gif[/img]
what other combos are out there that people are using?????
later
john [img]images/graemlins/40BEER.gif[/img]
WHTTRASH is offline
post #6 of (permalink) Old 02-11-2004, 12:10 PM
It's just another axle option out there. Currie makes a RR 9" centersection to gain some more clearance under the 3rd and get the drive shaft up compared to a std. 9".
Jeeper99xj is offline
post #7 of (permalink) Old 02-11-2004, 01:43 PM
Caver Dave's Avatar
You of all people should understand it...D-C put a dang front axle (D35) in the rear of your TJ!! [img]images/graemlins/shocked.gif[/img] Why should putting a rear up front be any different? [img]images/graemlins/tongue.gif[/img]
Caver Dave is offline
post #8 of (permalink) Old 02-11-2004, 02:09 PM Thread Starter
really???????????? what was the rig and year?????
later
WHTTRASH is offline
post #9 of (permalink) Old 02-11-2004, 02:51 PM
I see your point completely, I've never been able to justify building a 9"/60 hybred. Running a built D60 front and 14bolt rear has worked fine for me.
The front 14bolts that WMS builds are able to run a lower suspension then a Rockwell axle would require. The top loader axles like the Rockwells have 8 inchs of housing on top of the axle along with driveshaft clearance issue , which needs alot more lift to clear the motor .
W.C. is offline
post #10 of (permalink) Old 02-11-2004, 03:02 PM
elusive's Avatar
"Don't they flip the centersection when running up front? This would give a very high pinion.
Maybe there is more clearance over a d60 centersection"
if you flip the center section, the gears will turn backwards...this may cause a bit of binding in the x-fer case
elusive is offline
