Engine Woes - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-07-2004, 12:05 PM
JakeCJ
Engine Woes
Hello everyone, This is my first post, although I've been following the board for a couple of years now. Alright heres the deal....
I put a new engine in this summer, bought it from Quadratech, well my problem is that the exhaust mainfold was leaking I assumed it was cracked because the gaskets were so new on them, I figured this was not the case. I ordered a header, as a replacment for the "cracked manifold"(good excuse . Well as I figured the cracked mainfold was no big deal, I drove about 120miles on this. While I was driving my cj started to drive poorly, it started to stall, etc. Then started to burn white smoke, i pulled over and poped the hood. I noticed that coolant was bubbling out of the number 2 spark plug. I had it towed home, I feared that my head gasket popped but w/ only 10k on the engine and the jeep has never been close to overheating I didn't think this so. I took the mainfolds off and come to find out that exhaust manifold wasn't cracked but the gasket was infact ripped. Well I replaced the exhaust manifold with the header and reassebled. I also sucked all the coolant out of the #2 cylinder. It started up very rough, Now heres the problem.... 1) Alot of coolant blew out of the header 2)The exhaust leaks in the same exact spot. 3)The #2 clyinder fills up coolant 4)Obviously it runs very rough and burns white smoke.
Any ideas guys? My guess would be head gasket.. but why? Never overheated.... Also the header is leaking on the exact same spot as manifold. Now the header came with a very cheap gasket and I put it on anyways(bad mistake I think) Now could a cheap gasket cause any of these problems? Could these be concidence. Well I'm calling Quadratec on Monday when they open and see what they say. As it is still under warranty. Well any suggestions? Thanks!!!
post #2 of (permalink) Old 02-07-2004, 12:55 PM
Dirt Dog's Avatar
Re: Engine Woes
Welcome to the board and finally posting. [img]images/graemlins/smile.gif[/img]
Do a compression test to confirm that it is only one cyl. It doesn't have to have an overheat or anything to cause head gasket failure. Sometimes it just happens with age or defective gasket from the start. Also make sure there is no coolant in the oil to cause other problems.
So it's time to start testing, then wrenching.
Let us know what you find.
Dirt Dog is offline
post #3 of (permalink) Old 02-07-2004, 05:43 PM
JakeCJ
Re: Engine Woes
Ok I will test it tonight and let you guys know... Just curious if its not the head gasket what else could this be?
post #4 of (permalink) Old 02-07-2004, 06:13 PM
Dirt Dog's Avatar
Re: Engine Woes
Cracked head or block. If you have to pull the head it's always a good idea to have it checked for cracks.
I don't think there is too many other options. Unless the intake developed a leak inside right at the one cyl. But I've never heard of that happening.
Dirt Dog is offline
