Swapping yokes on J10 Dana 20 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-29-2004, 03:02 PM Thread Starter
Drury's Avatar
I've got my T-18 installed and am trying to figure out driveshafts. I'm pretty sure I'm going to need a double cordon for the rear due to the sharp angle. I understand that I need a special yoke for the double cordon. The standard yoke will not work.
Here's my question, The dana 20 I'm using came from the same 1978 J10 I got my T18 from and used a double cordon for the front shaft and a single for the rear. Can I swap the front and rear yokes so I can run a double cordon in the rear vs the front?
Drury is offline
post #2 of (permalink) Old 01-29-2004, 03:04 PM
Pooh-Bah
uglyjeepoffroad's Avatar
Re: Swapping yokes on J10 Dana 20
If the spline counts and the sizes are the same, i don't see why it would make a difference. I don't think they make "Dana 20 J- truck series ..." yokes. It is just a matter of spline count and u-joint size. [img]images/graemlins/grin.gif[/img]
uglyjeepoffroad is offline
post #3 of (permalink) Old 01-29-2004, 03:12 PM Thread Starter
Drury's Avatar
your right. I should've asked if anyone can confirm the spline count on the front and rear of the dana 20.
Drury is offline
post #4 of (permalink) Old 01-29-2004, 04:22 PM
Official Historian
WILL's Avatar
Dana 20's used 10 and 26 spline yokes on the front and rear. The only way to know what yours has is to take it apart. The part numbers are the same for front and rear.
WILL is offline
post #5 of (permalink) Old 01-29-2004, 06:49 PM
It should work, i know it works on dana 300's. You can also use xj 231 front yokes for dana 300's so if dana 20's and dana 300's have the same spline count it will work.
BarrelRoll
Jeeper99xj is offline
post #6 of (permalink) Old 01-29-2004, 10:17 PM
TOM85CJ7's Avatar
Hey Brad,
You need to climb under that beast and yank them off. I am pretty sure they will swap. If not front to back, then from your other 20. I think I have a D300 yoke laying around somewhere also. Pull them off and let us know what you find. By the way, there aren't any crush sleeves or anything like that on a D20 so just yank them off. You will probably need your cheater bar and something to hold the yoke.
Later,
Tom
TOM85CJ7 is offline
post #7 of (permalink) Old 01-30-2004, 08:59 AM
Official Historian
WILL's Avatar
The 26 spline dana 20 yoke is the same part number as the front and rear dana 300 yokes. It all comes down to whether or not the spline counts work. If your dana 20 CV yoke has the same spline count as the output shaft you want to put it on, it will work. Just be aware that the dana 20 has both 10 spline and 26 spline output shafts. The dana 300 just had 26 spline output shafts.
WILL is offline
post #8 of (permalink) Old 01-31-2004, 12:49 AM Thread Starter
Drury's Avatar
Pulled the yokes and they do swap front to rear. So good bit of info if you are looking to swap in a T18 from a J10. Chances are you'll need a double cordon driveshaft in the rear. If so, the front shaft on the J10 I pulled from was running a dbl cordon. You can swap that yoke from the front to the rear for your new set up and save $60 on a new rear dbl cordon yoke.
Drury is offline
post #9 of (permalink) Old 01-31-2004, 09:45 AM
Aaron871's Avatar
That may not be true on all J-10 Dana 20's.
My T-18 Dana 20 combo came out of a 1973 J-10, and the rear output is 23 spline and the front output is 10 spline. I can't swap mine. I've asked around (local shops) before and no one could tell me what year(s) Dana 20's came w/ a 23 spline output.
Aaron871 is offline
post #10 of (permalink) Old 02-02-2004, 10:52 AM Thread Starter
Drury's Avatar
I checked both of my Dana 20's and the 78 J10 D20 had 10 spline front and rear and my 78 CJ Dana 20 had 26 spline front and rear. It's probably a crap shoot on any of them....
Drury is offline
