Jeep Steering-Help! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-28-2004, 06:40 PM
DirtyBoy
Jeep Steering-Help!
Hello Ive replaced my leaf spring bushings with the poly bushings, new steering box, 4" drop pitman arm, new tie rods(greased) and I still have white knuckle steering. My roads in the area that I live are all crowned and my narrow track does have wandering problems with that, but even on the normal road it is still loose. I cannot afford a hydralic steering setup(unless you know a cheap way), and does a shackle reversal really help?...I did do a search but did not come up with any answers.thanks.
post #2 of (permalink) Old 01-28-2004, 07:10 PM
Dirt Dog's Avatar
Re: Jeep Steering-Help!
It doesn't by chance have longer than stock front shackles on it does it? That might be the answer right there. (that throws the caster out the window and gives the instant white knuckle)
Dirt Dog is offline
post #3 of (permalink) Old 01-28-2004, 07:21 PM
DirtyBoy
there heavy duty 3/8" longer only, because of lift laws Im all ready illegal with the 4" lift. I was thinking of cutting off the shoulder of the bushings and installing predrilled metal that would take up the space of the bushing to shakle area and having the nylock bolt stopping just before they rub and bind during normal flex.
post #4 of (permalink) Old 01-28-2004, 07:47 PM
Aaron871's Avatar
I would do 3 things.
1. I'd jack up one front tire and see if it had any play in it. Jack up both front tires and check for play.
2. Check for play in the steering shaft.
3. Check where the spring mount, mounts to the frame. (all suspension for that matter)
I am a novice at best. So take it for what it's worth, nothing.
Aaron871 is offline
post #5 of (permalink) Old 01-28-2004, 07:55 PM
Dirt Dog's Avatar
Right on the money Aaron. Since you really don't have "long" shackles it's time to look for play.
1" = 1 mile in a lifted swb jeep. Something has got to be loose. And it can be hard to find too. Just remember it doesn't take much. So time to start looking and ALL steering parts, then move on to all bushings.
Dirt Dog is offline
post #6 of (permalink) Old 01-28-2004, 08:05 PM
DirtyBoy
Ill give that a try and check for playin everything just did all the wheel bearings 4 months ago...but you never know. Still no word on the shackle reversal swap-if its worth it?!
post #7 of (permalink) Old 01-28-2004, 08:10 PM
I run a shackle reversal and it's one of my top 5 favorite mods in a long list of them that I've done on my CJ.
That being said, it will NOT cure the white knuckle steering problem you're describing, so follow the advice you've already been given to search for your problems.
Once you've gotten it fixed and you're ready, the shackle reversal will help with (in my case, eliminate) bump steer and will greatly improve the ride.
Clay
CJclay is offline
post #8 of (permalink) Old 01-28-2004, 08:12 PM
Aaron871's Avatar
Fix your steering problem before modifying it. Otherwise you wont know weather you did the reversal correctly or compounded the problem. If you compound the problem it gets very difficult to find.
Aaron871 is offline
post #9 of (permalink) Old 01-28-2004, 08:12 PM
Dirt Dog's Avatar
Shackle reversal has pros and cons. It will make a slight improvement on the road as far as driveabality, but not night and day. Fix the real problem first. Then if you want to make it a little better, then you can do it. Besides if you have looked into it you know about the nose diving issues under braking. [img]images/graemlins/crazy.gif[/img]
Dirt Dog is offline
post #10 of (permalink) Old 01-28-2004, 08:13 PM
I want to clarify quickly that I mean shackle reversal will improve the ride on the street. I don't believe there's a big advantage off road when you're crawling, but my rig is my DD and I like it to work well on and off road.
Clay
CJclay is offline
