I need some input on a water problem with a YJ.... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-25-2004, 01:49 AM
Twiterpated1966
I have a 91 YJ with the 4.0, and i recently added a modification which contains the oil that escapes through the valve cover instead of sogging up my air filter. Works great! But..... I seem to have a lot of moisture collecting in this canister also. It isn't coolant, but just water. ?? Now my oil is starting to get that "foamy" look to it. Any suggestions on what is causing it and how to remedy it? I would greatly appreciate any suggestions.
post #2 of (permalink) Old 01-25-2004, 08:34 AM
Dirt Dog's Avatar
Re: I need some input on a water problem with a YJ....
Is it foamy in the can or the engine?
The can is semi normal. A very little bit on the oil cap of the engine seems to be normal around me too. But only a little bit. Any more than that might be a problem. (or some oils seem to be worse than others for this too)
Dirt Dog is offline
post #3 of (permalink) Old 01-25-2004, 08:51 AM
Badcattledog
I had this problem with my 2.5. I think it is called blow-by.
After changing all the filters and PVC I took the hose to the air cleaner and extended it. Ran it down the side of the motor, like the old road tubes. No more water or foam. PVC stays clean. Not the best for the EPA but worked. 90YJ 03TJ
post #4 of (permalink) Old 01-25-2004, 12:13 PM
That can do more than cause apoplexy with the EPA gendarmes.
The road tubes were more properly called "road draft tubes" because the forward motion of the car produced a low pressure at the bottom of the tube, creating a draft which pulled blow by out of the engine, and clean air in through the oil filler cap, which had a filter in it.
With a PCV system, the flow is from the air cleaner through the hose into the engine, and from the valve cover through the PCV valve and into the intake manifold.
At high throttle openings, the blowby can overwhelm the PCV valve, and the excess goes out the intake hose to the air cleaner, which is causing your problem. But at other times that hose you've run down to the bottom of your engine is sucking unfiltered, dust-laden air straight into the valve cover.
Jim_Lou is offline
