Re: Antifreeze leak...where from?
1. Well HOP...
2. There's <font color="red"> ONLY THREE </font color> places,
3 For coolant leak inside the tub:[*]The heater core (and it's outlet - Inlet line)[*]The Input/Output Heater Hoses[*]Between the heater hose and the heater core tubing.
4. So, may I suggest,
5. You pull off the heater hoses[*]Clean the inside of the hose of corrosion[*]Clean the heater core tubing[*]Apply sealant to the tubing[*]Slip NEW clamps onto the hoses[*]Slip the hoses over the tubing[*]RE-clamp with NEW clamps][*]Tighten (Not over torque) the clamps.
6. Then clean up the mess and go for a ride.
7. If it's still leaking coolant...
8. It's the heater core.
