Uh oh, possible damage? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-20-2004, 11:43 AM Thread Starter
Well, on my way to work this morning there is a section of freeway that goes down hill a ways and it's a nice long gentle curve. I was late so I thought I'd let the CJ get up to about 70-75. About half way into the curve this very loud noise starts from the left front tire, like the wheel is rubbing on the body or something. With great alarm I get off the freeway and stop as soon as I can. Looking at it I don't see anything rubbing or anything wrong for that matter. Rather perplexed. I grab the hub and try to move it, nope, all 5 bolts are still tight. (I check these every 2 weeks just to make sure) As I'm staring at it trying to think what's wrong I'm scraping mud off of the hub housing, by the selector dial. Wait a sec, do I see the arrow pointing at a 4?! Yes, it is! I immediately check the other side. No, it's in 2 wheel. Apprently some curious "individual" decided to lock my drivers side into 4 wheel yesterday while I was in the office. Ugh! Well, I put it back in 2 wheel and no noise and all 'seems' fine. This probably was done before I drove home last night, so total miles are about 65, all freeway. What kind of damage might this have done? And why do people think they can play with someone elses vehicle? [img]images/graemlins/AR15firing.gif[/img] I hate that!
RiffRaff is offline
post #2 of (permalink) Old 01-20-2004, 11:59 AM
Re: Uh oh, possible damage?
1. Wear and Tear?
2. Yes...
3. Damage?
4. Likely not.
5. Pull the hub,
6. Check it out for damage,
7. Clean it,
8. Lightly lube it,
9. Re-assemble.
10. It's not a bad time to check those wheel bearings!
post #3 of (permalink) Old 01-20-2004, 01:20 PM Thread Starter
Thanks Leve. Any idea why it would make such a loud noise? It litterally sounded like the tire was rubbing on the body. Well, I've been meaning to upgrade to the Warn conversion ket anyway. This might be a good time to do it.
RiffRaff is offline
post #4 of (permalink) Old 01-20-2004, 02:00 PM
Carpal \'Tunnel
knifeboy2's Avatar
Check that the leaf spring hasn't started shifting into the tire. Occasionally if the things that hold the springs from shifting break they will rub into your tires in hard cornering. Banging them with a hammer and using hose clamps can fix that.
knifeboy2 is offline
post #5 of (permalink) Old 01-20-2004, 10:25 PM
OlllllllOCJ's Avatar
A few things come to mind that may or may not be relevant to your situation and noise.
The D30 and D44 front hubs have a plastic "Dust Shield" behind the spindle that can make some noise when the hubs are locked. That noise becomes much greater when the needle bearing inside the spindle is worn out. Put that in place along with worn out lower ball joints and you get some pretty loud sounds. I assume this is because the hub moves in relation to the axle, beyond the normal range, putting the u-joint in a bind. No damage as long as you stay on the road and nothing breaks.
While I have never seen this in a Jeep I would be happy to have some help changing the ball joints in my kid's Blazer that has a D44 front. Oversize tires make it worse and likely wear things out more quickly, the Blazer has 35 inch tires.
As for running highway speeds with locked hubs my other Son won the grand prize with his CJ-7. Spun off the front drive shaft and poked a silver dollar size hole in the T5 case taking a chunk from the transmission to transfer adapter with it. The drive shaft likely was at fault but I rebuilt both the T5 and the D300 completely. DON'T FORGET TO UNLOCK YOUR HUBS !
I know you didn't do it to yourself but it is easy to forget, I did a few times up until that adventure.
OlllllllOCJ is offline
post #6 of (permalink) Old 01-20-2004, 11:15 PM
Official Historian
WILL's Avatar
As was pointed out, a bad inner spindle bearing sounds like the most logical explanation.
WILL is offline
post #7 of (permalink) Old 01-21-2004, 12:21 AM
Driving with your hub engaged really isn't going to cause any major harm. My f150's hubs are engaged all winter. Some waggies came with drive flanges instead of actual hubs.
Barrelroll
Jeeper99xj is offline
post #8 of (permalink) Old 01-21-2004, 06:18 AM
[img]images/graemlins/crazy.gif[/img] Er......ah......JEEP PEOPLE! You are missing something here!.....WAKE UP!......!! [img]images/graemlins/mad.gif[/img] The noise that Riff-plus-Raff heard was the SPIDER GEARS racking like mad! When you lock only one hub, and the t-case is NOT in FWD, then the locked hub spins the spider gears and rotates the axle on the opposite side!!!! [img]images/graemlins/mad.gif[/img] SHEESH! Is no one awake out there???? [img]images/graemlins/crazy.gif[/img] Haven't you guys ever used "Oklahoma Rear-Axle-Only Low Range" by locking one front hub? By doing that, you cause the driveline to rotate, but having one front hub unlocked relieves stress on the front axle on hard surfaced roads. On Quadra-Trac Jeeps you can run in QT "Lock" and lock only one front hub to get the same effect. [img]images/graemlins/tongue.gif[/img] Here......take this pot of coffee........WAKE UP OUT THERE!!!!!!! [img]images/graemlins/crazy.gif[/img] Heck...take TWO pots of coffee. [img]images/graemlins/laugh.gif[/img]
CJDave is offline
post #9 of (permalink) Old 01-21-2004, 07:37 AM
Official Historian
WILL's Avatar
But the wranglers, chevy's and older dodges are the same way buy using the central axle disconnect. The driveshaft stays still, there are no hubs to disengage and the long side axle is seperated into two pieces with the inner one rotating backward and the outer one forward. The spider gears shouldn't be making noise. I still bet on a worn out inner spindle bearing.
WILL is offline
post #10 of (permalink) Old 01-21-2004, 06:03 PM
[img]images/graemlins/tongue.gif[/img] WILL.....you're right about the YJ's with the axle disconnect, and I SUSPECT that those vacuum-disconnect differentials have more that just a few thrust washers tossed in behind those spider gears as differentials have historically had. Since the factory intended the spiders to be rolling around in there as the Jeeper sped happily down the freeway in his YJ in 2WD, they must have made some changes in the way the spider gears are held. Differentials won't live long if the spiders have to turn constantly......usually from mismatched tires........unless some sort of special measures have been engineered into the spider gear carriers. In the case of Riff-plus-Raff, his differential has nowhere near that kind of capability, and I suspect it was protesting loudly, which was what he heard. [img]images/graemlins/tongue.gif[/img]
CJDave is offline
