PLEASE Help 360 Flywheel Identification - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-17-2004, 11:46 AM Thread Starter
Journeyman
Okay guys give me some help. I have used the search engine with no luck to find any of my numbers.
I pulled my tranny to inspect the clutch (I was getting some chatter) and got curious to make sure the PO put the correct flywheel on it (they dropped a 360 in it). I cannot find any of these numbers on any post here.
The casting # is 3212621. then there is L-178 and W-6.
Can I get some help identifying this flywheel or should I just buy a new one. I don't see any counter weights only balance holes drilled.
Help please
[img]images/graemlins/confused.gif[/img]
scrappy9 is offline
post #2 of (permalink) Old 01-17-2004, 12:30 PM
Re: PLEASE Help 360 Flywheel Identification
We have discussed it quite a bit, I just did a search for "flywheel" and got a lot of old threads to read.
I have a 360 flywheel if you want some photos of the counter weight location, and numbers.
this is info I copied from teh AMX mailing list a few years back.
_______________________________
Being in the parts business, I get to see many things that are more than
>just confusing, they're downright frustrating! I have in stock now, and
have
>seen in the past, THREE distinctly different versions of the flywheel with
>part #3197219. If you have one of these flywheels, and you want to follow
>along with the description that follows, place your flywheel flat on the
>bench with the casting number facing up and at 12:00. (like you're reading
a
>clock)
>Version #1: #3197219-C
>Crankshaft flange recess measurement: 4.500"
>Counterweight position: at 7:30
>Known to be out of a dead stock 1970 390 4-speed car.
>Version #2: #3197219-C
>Counterweight position: at 4:30
>Known to be out of a dead stock 1970 360 4-speed car.
>Version #3: #3197219 Does not have the "-C" after the casting
>number, but does have "E-25" (or other letter/number combo) cast in
>just above the counterweight.
>Crankshaft flange recess measurement: 4.650 (approx. 5/32" larger
>than the above two versions)
>Counterweight position: 9:30
>Exact application: unknown. Believed to be out of a 72/up 360 or 401
>(304's do not have a counterweight)
>All cast-in counterweights are one square inch, with the exception of
>version #3 which is 1/4" shorter. (length 1", width 1", depth 3/4")
ozarkjeep is offline
post #3 of (permalink) Old 01-17-2004, 12:31 PM
webjeep's Avatar
not sure on the casting #'s, but if you do decide to get a new one these guys Krage are great, mine including shipping (brand new w/ring gear) was only $102.00.
-web
webjeep is offline
post #4 of (permalink) Old 01-17-2004, 12:42 PM
Here are photos I just took of mine, you can see the number, and the location of the counter weight, read teh quoted info above, and you can ID the piece.
post #5 of (permalink) Old 01-17-2004, 12:52 PM
check this photo
post #6 of (permalink) Old 01-17-2004, 02:25 PM Thread Starter
Journeyman
Can somebody tell me what flywheel this is from!
I guess I have the wrong one on mine. Let me know what you think it is.
Thanks for all your help guys.
scrappy9 is offline
post #7 of (permalink) Old 01-18-2004, 12:14 AM
You could go to your local NAPA store and getthe correct one. A reman flywheel retails for around $65. Just give them your incorrect flywheel for the core.
crazycooter is offline
post #8 of (permalink) Old 01-19-2004, 10:17 AM
I have never seen an AMC flywheel that looks like that.
I enlarged and lightened up the pic, maybe someone can help!
post #9 of (permalink) Old 01-19-2004, 10:53 AM Thread Starter
Journeyman
I figured it was the wrong flywheel. Thats the vibration I have been dealing with. It shattered my last transmission and this one too. the T/O bearing is ready to fall apart.
Thanks Ozark.
scrappy9 is offline
