T4 transmission pops out of gear on 2nd & 4th - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-21-2003, 12:26 PM
dadare
Got a problem with my T4 tranny on the CJ7 not snapping into gear on 2nd and 4th, and reverse also. It will go in to gear, but a good bump will pop it out. CJ is a complete restoration including the tranny which didn't require any work when tore down. Checked it out, everything looked really good. Put about 500 miles on it since the restoration, absolutely no problems, then all of a sudden this. Any ideas?
post #2 of (permalink) Old 09-21-2003, 02:41 PM
general420's Avatar
Re: T4 transmission pops out of gear on 2nd & 4th
The T-4's two piece case is pretty week. When it starts to tourque the you get slop in the secondary gear cluster. 2nd and Reverse are usually the first ones to go. Every T-4 or SR-4 (Including mine) I've ever seen ends up this way. I'd look for a good T-176 as the T-4's are junk even behind stock motors.
general420 is offline
post #3 of (permalink) Old 09-21-2003, 02:54 PM
definetly sounds to me that your tub could possibly be interfering with your shifter... does your rig have a body lift? even if it doesn't, you may need to shave 1" or so away from the rear of the shifter opening... Think about it... 2nd, 4th, reverse... those are all on the bottom of the shift pattern, right? I had the exact same problem with my YJ and shaving the tub cured it...Sometimes the tub will let the tranny just *barely* go into gear... into gear well enough to where you can drive it, but a jolt will pop it out.
-pablo
YJOwnr22 is offline
post #4 of (permalink) Old 09-24-2003, 07:25 AM
Raduckal's Avatar
Those were two good answers. I've experianced both the above. My SR-4 lost a bearing popped a seal and would only stay in 1st and 3rd. A new tranny and a new shifter boot were very critical of the boot placement. I think that boot was a little stiff, but all is well now.
Raduckal is offline
post #5 of (permalink) Old 09-24-2003, 09:08 PM
dadare
Well, this one was easy. Crawled underneath tonight to take a closer look and it appears some genius decided he wanted my transmission enough to try and steal it. One side of skid plate was unbolted and hanging a couple inches causing tub to interfere with shifter. Don't know how far he got before realizing a T4 ain't worth the trouble.
post #6 of (permalink) Old 09-25-2003, 07:13 AM
Official Historian
WILL's Avatar
Or maybe your skidplate is like mine. I have had my bolts loosen up a few times on their own. Once they came all the way out and the passenger side was hanging. What made it worse was it was on I-44. Fortunately, I was only a mile from Joplin. Now I just check them once in a while. My transmission mount bolts like to do the same.
WILL is offline
post #7 of (permalink) Old 09-25-2003, 07:26 AM
Wow... you guys are lucky. My bolts like to, uh, tighten themselves and rust shut! [img]images/graemlins/chair.gif[/img]
YJOwnr22 is offline
