Dual Battery Wiring, not to beat a dead horse - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-20-2003, 10:25 AM Thread Starter
Folks,
Let me start by saying I did the search! I know this has been covered but I have some specific questions regarding dual battery wiring.
For more than 4 years I ran 2 red tops, with a continuous hold soleniod. One of my red tops finally died, and I have replaced it with a Yellow top (for winching and off-road accessories).
First question:
With a red and a yellow top, can I run a similair set-up. IE Continuous Hold Soleniod, oil pressure switch, and an over ride switch without damaging either battery? One deep cycle the other not.
Second question:
I my search I found CJDaves reference to a perfect dual battery wiring set-up from CJJOE. I was unable to find any wiring schema from that reference. Does anyone/CJDAVE have a copy of that set-up?
Third question:
Other than the standard, Hellroaring, painless, blah blah...does anyone have a tried and true wiring set-up that I am over looking. My goal is to isolate the batteries, (no $30.00 surepower, NAPA isolator commments please) charge both batteries, and possibly have a self jump option, at the same time I want it as simple, trouble free, and basic as I can make it.
I appreciate any help you can lend,
CJ_More is offline
post #2 of (permalink) Old 09-20-2003, 10:45 AM
Re: Dual Battery Wiring, not to beat a dead horse
1. I prefer solid state isolation, but you could do this:
post #3 of (permalink) Old 09-20-2003, 10:59 AM
For the simplest and most trouble free - but you have to remember once in awhile --
Hook them up both together - then use quick disconnects on the ground (-) sides.
Leave one disconnected for a week or two, then hook up the other ground and disconnect the first one. Alternating between them occasionally keeps both charged.
Then if one fails, simply swith to the other.
If you need extra power, hook up both grounds so they are in parallel for double the power.
By disconnecting the ground cable, you don't have a hot cable dangling.
RRich is offline
post #4 of (permalink) Old 09-20-2003, 11:01 AM Thread Starter
I haven't been on the board in a while. It's good to see some of the old gurus still around. Thanks for the quick responses!
Just a point of clarification.
In switch position off, the batteries are isolated, but still receiving a charge, correct?
CJ_More is offline
post #5 of (permalink) Old 09-20-2003, 09:19 PM
[img]images/graemlins/tongue.gif[/img] Actually, CJ& MORE, we ran a deep cycle marine battery plus one additional std battery as a second battery group for YEARS in our service trucks that had the big electric swinging boom and winch setups on them. We used the continuous-hold solenoid, a Hobbs oil pressure switch, and a push button over ride for emergency cranking if we somehow let the truck battery run down. The alternator didn't seem to care if we had different types of batteries since they were never connected unless charging was in process. [img]images/graemlins/tongue.gif[/img] The different battery type thing; when used under the correct conditions; is a non-issue. [img]images/graemlins/tongue.gif[/img] CJ Joe's setup was a duplicate of what we had and what you were running on the MORE Jeep. [img]images/graemlins/crazy.gif[/img]
CJDave is offline
