need help with t-15 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-17-2003, 01:17 PM Thread Starter
mav750's Avatar
need help with t-15
does anyone know of a good write up for rebuilding a t-15. Im sure its not that bad of a job, but having no experience with it id like something to use as a guide.
mav750 is offline
post #2 of (permalink) Old 09-17-2003, 06:30 PM
Re: need help with t-15
They are very easy to rebuild. Just dig in. Get your small parts kit and go to town. Watch how it comes apart. Ive done several for friends. Or replace with T18 [img]images/graemlins/grin.gif[/img]
Mike
mike34 is offline
post #3 of (permalink) Old 09-17-2003, 09:43 PM
Dex
will a t-18 bolt right up into a t-15 place?? and is it a better trans.???
Dex is offline
post #4 of (permalink) Old 09-17-2003, 09:54 PM
Dex no it will not bolt up. and yes it is Waayyyyyy better. it would require a new B/H and some driveline mods.
Its used in light trucks all the way up into 2 ton trucks and has the 6:1 granny gear(if ya get the right one) There is tons of info on this tranny on this board.
Mike
mike34 is offline
post #5 of (permalink) Old 09-17-2003, 10:08 PM
Dex
me too party animal, guess my 3rd sincro going out, geting a grind going into 3rd gear?
Dex is offline
post #6 of (permalink) Old 09-18-2003, 10:38 PM
Dex
mav... let me know what ya find out on tear down and rebuild and i'll do the same, even if there is a replacement for a t-15 that bolts right up and no other changes..
Dex is offline
post #7 of (permalink) Old 09-18-2003, 11:30 PM
doesn't the t-18 does use the same bellhousing as a t-15. (the crappola three speed used in cj's behind a 304)
I just put a t-18 in my jeep after I split the two piece t-15 shaft into 3 pieces... didn't work for some reason after that, dunno why [img]images/graemlins/smile.gif[/img]
Instead of using three bolts and a stud, I used 4 bolts, and just ground the head flat on one side of the bolt and stuck it through from the bellhousing side. You do have to grind the clutch fork a wee bit, but ten seconds with a sawzall and file and your good to go. You do have to round up new shafts, but if you live anywhere other than alaska that should be no biggie. The other problem I ran into was the torque arm. No matter how I tried I couldn't adapt the t-15 to a t-18 arm. Being a cheap SOB that I am, I ended up using a chunk of old grader blade, an old leaf spring bushing, a couple old body mounts, and a bolt, well you can see where I am going with that.....
I could be wrong here, but are the t-15 and t-150 one and the same?? I have a 77 cj5 that used to have the three speed, which tranny was it??
irjpr is offline
post #8 of (permalink) Old 09-18-2003, 11:45 PM
Dex
i have an adaptor from 350 chevy to what i was told was a t-15 and a 20 case only by some pix i posted; i bought this jeep this way (my 1st) i am trying to learn jeep.. and have rebilt mine ground up end to end, but keeping the same major setups and drive lines. if i can still inprove it , i'd like to know how? i'm still trying to learn all the termenolgy of a jeep that is spoke on here so bear with me...
Dex is offline
post #9 of (permalink) Old 09-19-2003, 01:17 PM
Aaron871's Avatar
It was a T-150. They stopped putting T-15's in after 1975.
Aaron871 is offline
