5.0 starter troubles - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-11-2003, 08:51 AM
sirhumpy
I've got my 5.0 in and running but I think I have a starter problem. I'm using a motor from a 93 tbird, flywheel and bellhousing from an 86 bronco. The starter is from the 93 and was used on an auto setup but I think that the starter gear is constantly meshed with the flywheel and therefore spinning all the time. I've already burned one up. Has anyone run into this problem or know if there are manual/automatic designated starters? Should I use a starter for the 86 bronco? I'm running stock manifolds so clearance shouldn't be an issue. Any help would be greatly appreciated.
post #2 of (permalink) Old 09-11-2003, 09:32 AM
Re: 5.0 starter troubles
I can't help you with the starter problem. I can offer that you find a Ford 5.0 mustang forum and ask them. I used those forums for a lot of my 5.0 specific questions.
zimm is offline
post #3 of (permalink) Old 09-11-2003, 08:50 PM
It rarely matters what YEAR the starter is from with 5.0s. But if the 93 engine was an automatic it probably has the wrong nose cone on it. Fords don't have any adjustment, your starter either is the right one, or it's wrong. If your's is constantly engaging I'd say replace it. Just make sure it matches the transmission/flywheel NOT the engine.
IN2DEEP is offline
post #4 of (permalink) Old 09-12-2003, 04:35 AM
I had the same problem. you will want to go get a starter off a 4 speed truck (these are all the same starters). The starter gear sticks out to far on the starter you have now and yes it is running with it constantly. This will fix your problem! [img]images/graemlins/40BEER.gif[/img]
lumpy85 is offline
post #5 of (permalink) Old 09-15-2003, 11:09 AM
sirhumpy
I ended up going with a powermaster reduction starter and it works better than I could have imagined and the 5.0 is on the road. Turns out that there is a flywheel with a 3/8 ring gear offset and another that uses a 3/4 offset. Thanks for all your help guys.
