convert f/s frame for use in older jeep - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-10-2003, 02:17 AM
Dose anyone have experience in converting a full sive chevy frame for use under a older jeep I have a older suburban frame and running gear that I am thinking of modifing to my cj. The suburban came stock with spring over axles and reverse shackle on the front, steering arm on top of knuckle, heavy duty frame, power steering. All of these modifications would have to be made to my original frame, so it would seem like a good swap if it will work I know that it will need to be shortened and the axles cut down but not sure if the frame will need to be narrowed. any comments would be welcome. Thanks Bob.
post #2 of (permalink) Old 09-10-2003, 09:08 AM
Re: convert f/s frame for use in older jeep
No direct experience, but some points to consider:
You shouldn't need to narrow the frame to fit the body - just make new body mount horns and weld them on to match the mounts on the Jeep body.
You'll have to examine the truck frame and axels to see what affect narrowing the axels will have. My memory is that the front wheels get pretty close to the frame at full steering lock.
If you narrow the frame then the engine and transfer case mounts aren't going to work either.
Another factor is the relationship between the front axel and the engine. I suspect that the axel is farther ahead of the engine in the Burb than in the Jeep.
At some point you might as well start from scratch. Then you have a nice clean frame with no patches or extraneous holes.
Jim_Lou is offline
