MC2100 adjusted! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-09-2003, 01:24 PM Thread Starter
MC2100 adjusted!
I entered a post on 9/3/03 about carb. adjustment for an MC2100, got a lot of info., and yesterday borrowed a vacuum gauge from a friend, and the results were good. I also opened up the diameter of the bottom hole for the accelerator pump linkage, (the top 3 were at .125 dia.), and had to grind a little off of the heel of the rod clip to make it fit because of the throttle linkage having a raised area on it. I have another question though, is it unusual to wind up with having the adjustment screws at different settings? The one to the drivers side is at 2&3/4 and the other is at 1&3/4 rounds, but it runs great, and I got a reading of near 20 inches of vacuum. I cleaned the smut and carbon from the spark plugs before I got started, and cleaned the tailpipe tip afterwards, so that I can see when I get home from work (38 miles round trip) if it's still blackening the tip or not. Thanks ya'll, for all the help. Please respond about the screw settings.
82' CJ7, 258 CID, (MC2100 & HEI conversions), T5, D300, Flowmaster series 45 muff., & 265/15's on the ground
HAYWIRE is offline
post #2 of (permalink) Old 09-10-2003, 01:41 PM
Re: MC2100 adjusted!
I am replacing my holly double pumper with a 500 cfm mc2100 and I am curious if there is any tricks to tuning one of these for a trail rig, like float level, spring under float, closing down the needle and seat?
lil_boss is offline
post #3 of (permalink) Old 09-10-2003, 03:50 PM
When you adjust the screws, you should be moving them in synch with each other. So when you try adding or subtracting a 1/4 turn, you do it to both screws at the same time, so that both end up with the same number of turns when you finish.
The way you have it set up now, one bore is delivering more fuel than the other. This could cause problems. Glad to hear you got it running right, but I would retune, adjusting them equally.
TiminMb is offline
