92 Wrangler Problems (updated) - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-09-2003, 12:53 PM Thread Starter
Journeyman
Location: Somewhere between the North Pole and South Pole
I have a 1992 Wrangler with the 2.5L I4, with a 5 spd transmission.
Yesterday I went home, came out a few minutes later and it would not start. It was cranking over but it would not fire. I did notice that on the gauge cluster the volts were not very high (barely over nine, it goes from 9 to 18?).
Later last night I went out to start it and it started right up.
This morning I went to start it and it started but the Oil pressure gauge went off the charts and the check engine light came on.
Last week I changed the oil, put two inline fuses in off the battery, and that was it. Also I have notice some wavering in my Oil Pressure gauge lately but I was figuring the sending unit was going out.
Has anyone had a problem like this, and could you give me some advice on what to look for. If I need to clarify some information I will do my best.
I went home last night and tried to figure out what was wrong with the jeep. The engine sounds fine, but there is a problem.
When the thermostat opens up the idle on the engine drops from 800 or so to 250-300. I can unplug the temp sensor and with in 5 seconds the idle is smooth. With the temp sensor plugged in you can give the engine gas and it will sputter, catch, then rev up. With it unplugged it will immediately respond to the throttle.
If it is a bad temp sensor then why is it causing such a rough idle when it is plugged in, and what does it have to do with the response to the throttle?
Thanks.
minnesota68 is offline
post #2 of (permalink) Old 09-09-2003, 02:37 PM
Re: 92 Wrangler Problems
On my 90 YJ, the oil guage pegs about 98% of the time (bad sending unit), and the voltage guage (which is what you've got - not amps) reads generally between 10V on a bad day and about 13.5 on a good day...I've checked the battery with a volt meter while the engine is running and it reads 13.9-14V, so the guage is a little wonky...check your grounds and your belts...
greyj is offline
post #3 of (permalink) Old 09-10-2003, 11:59 AM Thread Starter
Journeyman
Re: 92 Wrangler Problems (updated)
btt
