t-176 shifter problem? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-04-2003, 08:17 PM
gman
did a search but still lost,my shifter popped out of my t-176 it turned out the retaining cup had worn out .I bought the repair kit form 4wd but the tranny is stuck in reverse.Any one have a similar problem or know how to get it out of reverse thanks Gman.
post #2 of (permalink) Old 09-04-2003, 08:54 PM
Re: t-176 shifter problem?
you need to get the shifter back in place to get it out of gear so line it up with where reverse should be then slide the shifter back in sounds easier than it is i know... where in new york are you ??
3jeepguy is offline
post #3 of (permalink) Old 09-04-2003, 09:28 PM
gman
thxs, I've been trying that to no avail. I did a search and saw someone had a similar problem and had to remove the shifter and use a screwdriver, just wondering exactly how he did it ? I pm'd him and waiting to here anyone else? or does anyone have a link to a diagram of a t176 that might help. i live out on the east end of long island.
post #4 of (permalink) Old 09-04-2003, 10:34 PM
mib4840
I had an 80 CJ5 with a T176 in it. It did the same thing. Try using the long and thick screw driver as the stick shift and have someone gently, and carefully, rock the Jeep back and forth while you try to shift out of reverse.
post #5 of (permalink) Old 09-04-2003, 10:58 PM
gman
thxs guys ,this forum is the best!!!! Do i need to push tha puck in for it to go into reverse?? thxs again Gman
post #6 of (permalink) Old 09-05-2003, 08:31 AM
If you can't line things up with a screwdriver, you may have to remove the top cover off the tranny and manually move the synchros and reverse sliding gear to the neutral position.
I had a similar thing happen to mine, except that it ended up in 2nd and 3rd gear at the same time - and jammed hard. I had to remove the cover and manually put it in neutral.
dschwab9 is offline
post #7 of (permalink) Old 09-05-2003, 04:52 PM
gman
thxs Derek, It seems that mine is jammed that way also. Anything I should know about removing the cover, it seems to be hung up, maybe a fork or something hanging down?
post #8 of (permalink) Old 09-05-2003, 07:08 PM
Official Curmudgeon
CJ7Taz's Avatar
DON'T
What makes you think it's in 2 gears? I thought it was in reverse.
CJ7Taz is offline
post #9 of (permalink) Old 09-05-2003, 09:12 PM
gman
I got it to pop out of reverse but not allthe way back to the neutral position. with the shifter inserted i can't move it at all, even with rocking the vehicle. now it seems to be stuck between gears or something. sorry never pulled apart a manual tranny before.
post #10 of (permalink) Old 09-05-2003, 09:31 PM
Official Curmudgeon
CJ7Taz's Avatar
CJ7Taz is offline
