Need to know what auto fits? AMC v-8 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-04-2003, 06:04 PM
Ok, unfortunately I am having a lot of trouble getting my T-18 to work properly and have decided to ditch it and go with an auto (my wife says so). I need to know what auto will fit behind an AMC 360 and dana 300. I realize I might need an adapter, but just let me know the possible combos.
Is a TH400 4x4 the same as all TH400 4x4 trans?
Is the 727 4x4 the same as all the 727 4x4 trans?
As a final note, I have a rebuilt (less than 10,000 miles) TH700R that was from a corvette (so it's a 2x4). Anyway to use that or am I better off (cheaper) to go with a TH400. Plus is the TH400 more durable in the end?
Thanks, John
post #2 of (permalink) Old 09-04-2003, 06:12 PM
Re: Need to know what auto fits? AMC v-8
You could also go with a TF6(999), aka the A904, Chrysler's version of the non-overdrive 3 speed auto. I'd also look into a TH350 before the 400 simply because the TH350, lockout version, gets the horses to the wheels more efficiently than a 400 and it is much shorter so there is no problem with driveline angles. Not to mention TH350s are a dime a dozen and easily built for high performance, and [img]images/graemlins/AR15firing.gif[/img] relatively inexpensive on the upgrades.
mobdawg is offline
post #3 of (permalink) Old 09-04-2003, 08:49 PM
jeepgod's Avatar
whats wrong with the t18???
for an auto.. id use a tf 727 from a grand wagoneer.. the full size version.. it will bolt to the 360.. and the d300 will bolt up to it... it has to be an amc tf727.. since the bolt patterns are not all the same.. with this combo.. your front drive shaft will be close if not hitting the tranny pan... if you have like 4" of lift.. no problems.. if not.. you can try a clocking ring.. or some pan modifications.. or a jointed front driveshaft.. from high angle driveline..
all th400's are not the same.. only the amc version has the amc bolt pattern.. to the engine..
if you use that 4x2 tranny... you'll need atleast an adapter on the rear to mate up any kind of transfer case.. unless you divorce mounted... and you have ten tons of room to do this with.. plus a 700r will require an engine adaptor.. and transfer case adapter.. both big bucks.. same way with the th350/th400...
jeepgod is offline
post #4 of (permalink) Old 09-04-2003, 10:57 PM
man, most folks would love to have that T18!
what is giving the problems about it?
ozarkjeep is offline
post #5 of (permalink) Old 09-05-2003, 08:51 AM
I have bought too much to get the T-18 to work and it still isn't working right. Problems with the slave cylinder, now I took it around the block and it is making a weird noise and I can not pinpoint it to the transfer case or the trans right now.
Anyone want to trade. I will pull all the stuff with the T-18 for a top notch auto. The t-18 may need a rebuild or the x-case may need a rebuild.
I also have new in the box set of crawler gears for the dana 20.I guess I will call around today for a 727 for a grand wagon.
Thanks for the info on the trans guys. I just knew you could help. It is too bad about the T-18 not working out for me. If I had more time and money and time and a little more money I'm sure I could get the NV4500 and atlasII to work for me. [img]images/graemlins/grin.gif[/img]
Anyway thanks again. My wife is happier now that it will have an auto also, she will get to drive it.
post #6 of (permalink) Old 09-05-2003, 11:23 AM
Drury's Avatar
PM'd ya.
Drury is offline
