Help w/G.Wagon springs. Anyone got them on a CJ7? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-04-2003, 02:37 PM Thread Starter
TOM85CJ7's Avatar
I have a set of springs from a G.Wagoneer. They are stock springs. I was thinking about using them on my CJ7. Does anyone know how the measurements compare? The fronts look very similar. The rears are definitely longer. I am planning to stretch my CJ7 so they might still work. I am just curious how they will hold up in a SOA configuration. Anyone have any experience with these springs?
Thanks,
Tom
TOM85CJ7 is offline
post #2 of (permalink) Old 09-04-2003, 03:24 PM
Mike86CJ7's Avatar
Re: Help w/G.Wagon springs. Anyone got them on a CJ7?
For what it's worth, a guy in my club has a set of rear SJ springs in the back of his '88 XJ. They're SOA and seems to have held up fine over the past few years.
Mike86CJ7 is offline
post #3 of (permalink) Old 09-04-2003, 03:54 PM
Caver Dave's Avatar
FWIW, WBCarver is modding his CJ7 to use Waggy front leafs at both ends. They look pretty favorable over YJ leafs (w/ V8, 8274, big old bumper, etc.).
Brent tried to "talk him into" using the rear Waggy leafs (ala Holbrook "longleaf") [img]images/graemlins/smirk.gif[/img], but was frowned upon. The rear hangers would end up being only 6" apart using them at both ends.
Measurement wise, they're only an inch or 2 longer than YJ leafs (assuming that CJ rears are the same???) and the distance from the eye on the short side to the center pin is the same (+/- 1/4")... I've got some pics I can send (with Bills permission of course [img]images/graemlins/grin.gif[/img] ) if you'd like to see what he's doing.
Caver Dave is offline
post #4 of (permalink) Old 09-04-2003, 04:04 PM Thread Starter
TOM85CJ7's Avatar
Hey Caver,
So CJ rears are the same length as YJ fronts? Waggy fronts are 1-2"s longer than YJ fronts? Am I correct?
Thanks,
Tom
TOM85CJ7 is offline
post #5 of (permalink) Old 09-04-2003, 04:12 PM
mbalbritton's Avatar
Brent tried to "talk him into" using the rear Waggy leafs (ala Holbrook "longleaf") , but was frowned upon. The rear hangers would end up being only 6" apart using them at both ends.
HEY! I thought it looked pretty damn straight forward and seemed like a good idea..... uhoh, how many times have we heard that before.... "seemed like a good idea at the time...." [img]images/graemlins/grin.gif[/img]
mbalbritton is offline
post #6 of (permalink) Old 09-04-2003, 04:36 PM
Pooh-Bah
pbmcauliffe's Avatar
I am redoing the CJ7 right now and have some waggy front leafs (7leafs) I am using. In the front I am going to stay with the rear CJ7 mix pack I was using. In the rear I am using the waggys because they are a little longer and have a 22"/24" split to them, so you can get 2" more wb by running them longside forwards. I ended up pulling two leafs out of them and it sits at the height it did before.
pbmcauliffe is offline
post #7 of (permalink) Old 09-04-2003, 08:24 PM
Caver Dave's Avatar
I'm positive the Waggy springs are a few inches longer than the YJs...with an offset pin that's real close the same as the YJ.
I was guesstimating on the CJ rear/YJ similarity....anyone know for sure?
post #8 of (permalink) Old 09-04-2003, 08:34 PM
jamgood96's Avatar
I'm running a set of CJ rear springs on all four corners of my YJ. The seem a little bit shorter than the YJ ones. I kind of wish I hadn't gone that route, as my shackle angle sucks.
jamgood96 is offline
post #9 of (permalink) Old 09-04-2003, 09:08 PM
Also going to be using the waggy springs in the front of my CJ... well, actually they're from a J10, but are the same thing.
They're only about 2" longer than the stockers at rest, and offset 2" on one end, for the aforementioned wheelbase increase. They flex well, too. Arc translates to about a 1.5" lift if run SUA.
You can also use them in the rear for the same effect, but since they are so sproingy, a traction bar is usually necessary to prevent axle wrap.
fullygruntled is offline
post #10 of (permalink) Old 09-09-2003, 05:30 PM
OK, coming in a little late here.
Got Waggy front springs on the front of my CJ.
Not sure yet what I am gonna use on the rear. Probably another set of Waggy fronts.
The Waggy front springs are just a little longer than the YJ springs but the waggy rears are a BUNCH longer. Putting them in the front was going to open up a can of worms with the steering. And in the rear in order to get the W/base stretch you would have to either stretch the frame or relocate the gas tank or both.
Here is a pic of front waggy spring compared to a YJ rear spring. Like Caver Dave said, the center pin on the short side is only about a 1/2" off from the YJ.
So what we did is do a shackle reverse and move the front mounting oint forward about 1/2". Which puts the center pin back where it started. ANd relocate the rear mount back about 2"
Now you have to humor me about all the vise grips in the mock up. But here is a Waggy front installed (sorta)
Here is a YJ rear installed. (Again only sorta)
Although not the best pics, you can see the difference in the rear hanger in relation to the body outrigger.
In case anyone cares, here is the Waggy spring at almost full stuff. The Jeep started to come off the Jackstand so I quit lifting.
Will try to have some better pics in a couple days.
Caver if you have some other pics you think you want to post go ahead.
HTH,
Bill C
wbcarver is offline
