Timing + = higher engine temps, right? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-04-2003, 08:21 AM Thread Starter
I talked to an engine builder at a street rod show and I got some confusing information, now I need to confirm.
All else being equal, more timing will yield higher engine temperatures right?
This engine builder told me the opposite, that retarded timing (lower) would cause higher temps.
Which is right?
pnut is offline
post #2 of (permalink) Old 08-04-2003, 08:29 AM
84_CJ7's Avatar
Re: Timing + = higher engine temps, right?
I believe the reason that it would run hotter retarded is that the engine is having to work harder to achieve the same power - less efficient.
Scott
84_CJ7 is offline
post #3 of (permalink) Old 08-04-2003, 08:45 AM
Advanced timing will cause higher combustion chamber temperatures. Taking the timing either way from ideal will cause the engine to generate more heat because it's using fuel less efficiently. Withing reason the temperature won't change because the thermostat will control it.
REALLY confused now?
Jim_Lou is offline
