Dana 44 breathers - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-03-2003, 09:13 PM Thread Starter
Dana 44 breathers
So I got the Dana 44's out from my scout and there are no breathers on them. (I scoured every topside inch of those things looking for them) Do they not need them or what is the deal here? I am going to tear em down, so if they need em, it would be an easy time to drill an tap the tube.
Thanks
irjpr is offline
post #2 of (permalink) Old 08-04-2003, 12:04 AM
Re: Dana 44 breathers
Seems funny you can`t find them. Every axle I`ve seen had them. Anyway, just do what you said and put in
your own. You should have them. I would put them in the top of the housing though, as opposed to the tube.
4x401CJ5 is offline
post #3 of (permalink) Old 08-04-2003, 12:06 AM Thread Starter
ok, I just said tube since thats where it is on my AMC 20..
Thanks
irjpr is offline
post #4 of (permalink) Old 08-04-2003, 08:51 AM
I Do This For The Glory
JEEPN's Avatar
The rear breather is at the top of the bolt that holds the brake line assembly to the axle on the passengers side tube. The front one is on the pumpkin housing itself. I tapped both mine and installed compression fittings for larger lines.
JEEPN is offline
post #5 of (permalink) Old 08-04-2003, 09:29 AM Thread Starter
that makes a little more sense, maybe someone busted it off and then simply replaced the bolt?? All the brakeline clips are secure, but none have nipples on them for breathers.
As for the front, I found it, or where it should go anyway...
Thanks
irjpr is offline
post #6 of (permalink) Old 08-05-2003, 03:08 AM
It should be on the bolt that holds down the brass block on the end of the rubber brake line. It's a hollow bolt with a little cap on it. I took the cap off on mine and hooked a rubber hose to it that runs up to the area behind the gas filler.
dschwab9 is offline
