-   -   CJ7 Starting Problem (https://forums.off-road.com/jeep-short-wheelbase/173110-cj7-starting-problem.html)
qdog 08-03-2003 08:59 PM
I was trying to help a friend get his 83CJ7 running today with no luck...Here is the deal:
When the key is in the start posistion the engine will start and run but when you release it to the run posistion it turns off. We tried a new ignition module and switch. Anyone have any sugestions?
Thanks,
Mike
**DONOTDELETE** 08-03-2003 09:04 PM
Re: CJ7 Starting Problem
Yeah that is my jeep i need the Help, thank you for coming over, i checked all the wires for the mod. for shorts and they were all good I am about to test all the wiring for the switch to the firewall for some. Thank you again.
John
ddieken 08-03-2003 10:58 PM
The only thing that comes to mind is that there is a problem between the lock and the switch itself. There is a rod with a hook on the end that goes down from the lock to the switch and that toggles the off/run/start setting. If that linkage is not set right, then the switch could return to the off position without you turning off the key. I suggest that you check the linkage and perhaps try the operation of the switch without the linkage connected.
AllLockedUp 08-04-2003 07:12 AM
I had the same problem. I had lost my 12v to the coil when the key was in the run position. I traced it back to a rotted connector in the junction block at the firewall. I wound up throwing a toggle switch and relay in to control power to the module and coil until I can get a new harness to swap in (this fall).
