YJ hard Brake pedal - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-02-2003, 08:27 AM Thread Starter
YJ hard Brake pedal
Once in a while, My 87 YJ brake pedal will feel hard as a rock then I hear a pop, then the pedal feels normal again.
Take note, that when it is hard, it still slows the Jeep down but not as fast and it is not pulling.
Possible master cyl? Brake booster?
Any Ideas?
[img]images/graemlins/givemebeer.gif[/img]
jeepride is offline
post #2 of (permalink) Old 08-02-2003, 01:12 PM
Re: YJ hard Brake pedal
Brake booster...check it out...You said that it stops ok during the problem, then it is hard pedal, then back to normal. Must be a booster going bad, or leaking vacuum lines...
Check for leaks at all wheels, and master cylinder.
tincan is offline
post #3 of (permalink) Old 08-02-2003, 01:18 PM
Dirt Dog's Avatar
Ditto on the booster. Check it first. I don't know what the "pop" sound is. [img]images/graemlins/confused.gif[/img]
Dirt Dog is offline
post #4 of (permalink) Old 08-02-2003, 01:22 PM
Aaron871's Avatar
Is the pedal binding?
Aaron871 is offline
post #5 of (permalink) Old 08-02-2003, 03:03 PM Thread Starter
I will recheck all the fittings and wheel cyls, calipers ect for leaks.... Whould the proportioning valve do something like this? The pedal doesn't bind.
jeepride is offline
post #6 of (permalink) Old 08-05-2003, 07:29 PM Thread Starter
I can get it to happen EVERY time I panic stop now! HORRAY!!!! If I press the pedal down normal it stops perfect. If I step on it fast. Pedal is hard, Jeep slows down, Then I let up on the pedal and press it down again, a slight pop is heard, then the Jeep tires will lock up. I am going to try and locate a Brake booster. Any Idea on if they sell them aftermarket?
My thought on Junkyard parts is that it's probably as good as the one in the Jeep now.
jeepride is offline
post #7 of (permalink) Old 08-09-2003, 04:19 PM Thread Starter
I just got done replacing my brake booster ($78.00) and master cyl ($64.00). The booter is a rebuilt unit. The master cyl is a new unit. The new master cyl is made out of cast iron. The original one is aluminum. I checked out a remanufatured Master cyl but got discouraged when the casting looked worse then mine. The brakes never felt SOOOOO Good.
jeepride is offline
