adapting a 350 to t-176 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-30-2003, 04:12 PM
drunkinhillbilly
i have a 350 and i have a t176 and i want to put the two together but i dont have the right bellhousing. i have heard that i could use a bellhousing out of a 80-83 cj with a inline 4. however there are no junkyards around me that cary anything jeep. [img]images/graemlins/frown.gif[/img] i called advance adapteres but i dont have the money for that plus they say that if i get there bellhousing i have to use there clutch because all othere clutches will not fit. does any one know of any other way of adapting these two? or can any one point me in the direction of a jeep specific junk yard that i can call.
thanks, Colin [img]images/graemlins/givemebeer.gif[/img]
post #2 of (permalink) Old 07-30-2003, 04:21 PM
lomodyj's Avatar
Re: adapting a 350 to t-176
I know driving aroung CT looking for Jeep yards is a pita but try these:
Yales salvage in Montvalle, they list several parts CJ's
Websters in Terryville. They also list several tcases.
lomodyj is offline
post #3 of (permalink) Old 07-30-2003, 04:30 PM
drunkinhillbilly
nope neither of them have any cjs left. i need to move to a diffrent state. any other sugestions even out of state, i could get something shiped.
thanks anyway, colin
post #4 of (permalink) Old 07-30-2003, 04:39 PM
I'd be interested to see if a 4cyl bellhousing will work too. I was planning on getting the AA BH from a friend who no longer needs it when I swap in my Vortec 350
AllLockedUp is offline
post #5 of (permalink) Old 07-30-2003, 05:57 PM
Official Curmudgeon
CJ7Taz's Avatar
My understanding is that the 4 banger bellhousing will not work. I've got the AA bellhousing and using a standard GM truck flywheel with pressure plate for a 12" clutch. The passenger car flywheel/pressure plate will work if you're happy with the smaller clutch. The GM clutch spline is wrong but I believe mine is stock Ford (been a while I don't remember for sure). It also uses the OEM Jeep throwout bearing and clutch arm.
There was an adapter plate available for the 350 to T176. About half the cost of the bellhousing.
CJ7Taz is offline
post #6 of (permalink) Old 07-30-2003, 06:31 PM
I did a little research on AA's website. If you can find a bellhousing from the Iron Duke (GM 4cyl used in Jeeps), you are all set and don't need any additional adapters. The question becomes - does the T176 bolt to the Iron Duke bellhousing?
post #7 of (permalink) Old 07-30-2003, 09:30 PM
general420's Avatar
I just went to the shed and looked at my iron duke bellhousing (spare parts are cool [img]images/graemlins/grin.gif[/img]). It has to be drilled to work with the ford pattern trannys (like the t-176) but the bosses are already there, just not drilled. I know they'll work with the sr-4, t-4, t-5, and t-150. But with a little drilling it should work. Just FYI, to use the iron duke bellhousing, you have to use the smaller 153 tooth flywheel and 10.4" clutch. It's what I have in mine now and so far so good, but an 11" or 12" would be preferable.
general420 is offline
post #8 of (permalink) Old 07-30-2003, 09:44 PM
Journeyman
I've actually got one of those bellhousings that you are asking about, unfortunately I have to hold on to it for the very same reason you're asking. And yes it will bolt straight up to a GM 350. It came out of an 83 CJ-7 with the GM 4 cyl with a 176 bolted to it. As long as it is the GM 4 cyl then it will work. I still have the 4 cyl if anyone wants one for some reason. My plan is to use the bellhousing when I upgrade my 5.
chjeeper is offline
post #9 of (permalink) Old 07-30-2003, 09:56 PM
Journeyman
Sorry fellas, I forgot to finish the statement, The 176 that was hooked up to the bellhousing in question is in my 5 now, I had an SR-4 that went south on me so i picked up the whole drivetrain out of the 83. The bellhousing used by the SR-4 just had to be drilled out a little and tapped to bolt the 176 to it and it works fine. If I remember right, the shafts are the same diameter and length on the SR-4 and the 176 in this case. Sorry for all the numbers.
I believe Lakewood also makes a bellhousing to do the 350/t176 conversion, but I believe it's a little pricey.
chjeeper is offline
