Yj "service reqd" light - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-29-2003, 01:22 PM Thread Starter
Yj \"service reqd\" light
"Service reqd" light, is there a quick reset. My yj has been maintained, i just don't want to pay some kid to plug it into a computer to tell me what the problem is. I think i have a bad o2 sensor ( my freeze plug leaked on it for some time). I tried to do the on/off key thing- no luck. Anyon [img]images/graemlins/confused.gif[/img]e have any ideas?
rossmoor is offline
post #2 of (permalink) Old 07-29-2003, 01:27 PM
Re: Yj \"service reqd\" light
1. There's a timer that comes on at multiples of 80,000 miles to
2. Warn you to check your Emissions...
3. Usually it's not a problem...
4. How's the Jeep running?
post #3 of (permalink) Old 07-29-2003, 01:30 PM Thread Starter
Jeeps running good. No problems
rossmoor is offline
post #4 of (permalink) Old 07-29-2003, 02:10 PM
1. My guess... it's the Emissions Reminder.
2. There's two ways of turning it off.[*]Drilling a hole and resetting the box [*]Swapping the Box.
3. I've got the drilling directions Somewhere...
4. But I can't promise I'll be able to fine 'em.
post #5 of (permalink) Old 07-29-2003, 02:23 PM Thread Starter
That would be cool if you could find out how to drill and reset that box. If you can't find it i will just have to look into replacing it. Thank you for your help, you always seem to know. Time to put the Jeep in the garage before it tries to become a hot tub again ( thunder storms) . At least it's hot! [img]images/graemlins/beach.gif[/img]
rossmoor is offline
post #6 of (permalink) Old 07-29-2003, 03:54 PM
Re:
JEEP
1988-90 CHEROKEE, COMANCHE, WAGONEER & WRANGLER
Service Reminder Indicator (SRI)
Vehicles are equipped with SRI on instrument cluster. This light will come on one time at 82,500 miles to alert driver that emission service is required. At this time, oxygen sensor and PCV valve must be replaced and all other emission components should be inspected, and serviced or replaced as necessary.
SRI timer is located under dash, near accelerator pedal or to right of steering column. Timer cannot be reset. To turn off light, timer must be replaced or disconnected. Since timer and sensor are interdependent, if timer should fail prematurely, oxygen sensor should be replaced at same time to preserve correct replacement interval.
To replace timer on Cherokee, Comanche and Wagoneer models, remove cruise control module (if equipped). Remove timer mounting screws. Disconnect electrical connector. On Wrangler models, remove timer mounting screws. Disconnect electrical connector. To install, reverse removal procedure.
1991-92 CHEROKEE, COMANCHE & WRANGLER
Vehicles are equipped with SRI on instrument cluster. This light will come on one time at 82,500 miles to alert driver that emission service is required. At this time, oxygen sensor must be replaced and all other emission components should be inspected, and serviced or replaced as necessary. Chrysler's Diagnostic Readout Box (DRB-II) tester is required to reset the SRI.
Reset Procedure
Using DRB-II tester, access SELECT SYSTEMS. Select appropriate engine. Select with or without A/C. Select FUEL & IGNITION. Select ADJUSTMENTS. Select RESET SRI LIGHT. Reset SRI light. When DRB-II is finished resetting light, DRB-II display will read SRI LIGHT IS RESET.
post #7 of (permalink) Old 07-29-2003, 04:51 PM Thread Starter
Re:
Thank you for the good information. I figured i would need to replace those parts- the normal stuff-. I will add this to my quick growing knowledge of Jeep!
It's good to be a L-7.
rossmoor is offline
post #8 of (permalink) Old 07-29-2003, 05:43 PM
beee240's Avatar
Re:
Just unplug the bulb....
It's about as wothless as the light that tells you when to shift.
beee240 is offline
