95 Wrangler won't start - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-28-2003, 03:14 PM
95 Wrangler won\'t start
I have a 95 Wrangler with a 2.5 liter 4cyl engine which I replaced with another used engine. Now it won't start. I am getting no spark. I just cranks. What am I missing? Thanks for any help.
post #2 of (permalink) Old 07-28-2003, 07:24 PM
babypoo's Avatar
Location: Milwaukee(which is algonquin for the good land)WI U.S.A
Re: 95 Wrangler won\'t start
Internal Combustion Engines need three things to work air, fuel, and spark. Your not getting spark...are you positive you are getting fuel if so, check your coil, if not your coil...make sure your rotor is turning. If you are not getting fuel or spark check your CPS and your cam sensor I have had these go bad and never even checked to see if I was getting fuel just automaticly thought it was a spark issue when in reality I had no spark and no fuel. Check all your fuses.
John
[email protected]
babypoo is offline
post #3 of (permalink) Old 07-28-2003, 09:21 PM
Check ALL the fuses! This sounds really stupid, but my buddies 95 YJ wouldnt start for several days. It turned out to be the dome light fuse! I guess it was tied in some how, but I still dont know where.
Damn square headlights! [img]images/graemlins/laugh.gif[/img]
teejay68 is offline
post #4 of (permalink) Old 07-29-2003, 10:44 AM
GeeAea's Avatar
Assuming that you've connected everything back up AND the old setup was firing when you took it out ...you've got some defective part on the new engine.
I'm not sure what your engine needs to give you spark. The newer ones use a crank position sensor ...which I think is on the trannie bellhousing. The distibutor just triggers the fuel injector(s).
Anyway ...is your check engine light hooked up and functional? Is this an otherwise stock installation? If so ...check the engine codes. Check out this page. . It "may" point you in the right direction.
GeeAea is offline
post #5 of (permalink) Old 07-29-2003, 12:50 PM
1. Welcome to the forum.
2. Please complete your user profile:[*] It's a nice thing to do.[*] It's helps to know who we're talkin' to.[*] It helps to know what's your ride.[*]It helps to know the local in which you live.
3. Read the New Posters Message at the top of the forum.
4. Participate! Two brains are better'n one!
5. Ok..
6. You've got good information...
7. Now start giving some feed back.
8. They ignition system is fairly simple:
9. Have you found out if the ASD relay is engaging?
9. If it is... you won't get the fuel pump to work,
10. Or spark.
11. It's engaged by the ECM NOT sensing
12. The Crank Position Sensor,
13. What's the Computer Codes say?
