98 TJ Check Engine Light Problems - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-28-2003, 12:33 PM
Had the codes read this weekend-- there were three
1. TPS- malfunction
2. Detected #1 Cyclinder Misfire
3. Speed Sensor on the Tranny -- its a manual transmission
Well I decided to get a bunch of throttle body cleaner, eletrical parts cleaner, and ignition seal and goto town. I took apart every single electrical connection under the hood and cleaned and sealed- I never knew there were so many. Then I took off the throttle body. Unbolted all three sensors and cleaned the heck out of everything bolted everything back up and I still have the problems. I even replaced the distributor cap and rotor and cleaned it all up real nice.... So I'm guessing I need to just replace the TPS? Also where is the speed sensor on the tranny located? I can barely fit my hand around the tranny so how the hell am I going to replace this sensor? My last question is could the cyclinder misfire be from bad sensors? Or what? [img]images/graemlins/thud.gif[/img]
post #2 of (permalink) Old 07-28-2003, 12:44 PM
Re: 98 TJ Check Engine Light Problems
Now thinking alittle more indepth to the day this all started... i remember the exhaust sounded like it had a hole or I broke a seal or something... this would in turn affect the O2 sensor? But after my visual inspection of the exhaust i dont see any holes -- any ideas?
post #3 of (permalink) Old 07-28-2003, 01:04 PM
Are your dash guages still working? My guages used to quit working, the airbag warning would come on and the check engine light would come on. It was a loose connection in the dash.
upalittle is offline
post #4 of (permalink) Old 07-28-2003, 01:09 PM
Yea that goes off and on... I just hit the dash and it turns back on... I am getting alittle hesitation though so its not a gauge problem.
post #5 of (permalink) Old 07-28-2003, 02:39 PM
elusive's Avatar
the vehicle speed sensor in in the transfer case.. lay under the jeepat the rear and look forward towards the cae.. thats it.
hesitation and wierd sounding exhaust.. sure its not a clogged cat?
elusive is offline
post #6 of (permalink) Old 07-28-2003, 03:05 PM
the weird sounds exhaust sounds like I cracked something in the exhaust pipe when i got done offroading... I got lost in the woods and had to do alittle more in the stock TJ than I really would have liked to... After that I've had a mess of problems. Its not a clogged cat. Elusive think I should take the sensor off the xfer case and clean it? then see?
post #7 of (permalink) Old 07-28-2003, 03:14 PM
Sounds exactly like the problem I had. I could press the plexiglass near the odometer/tripmeter knob and everything would come back on until I hit the next bump. Finally I pressed really hard (might have been some frustration showing) and it hasn't gone off again in more than a year and 16,000+ miles. I think I've cured mine. Good luck with yours.
post #8 of (permalink) Old 07-28-2003, 03:21 PM
I dont know if you read my first post... THE PROBLEM has nothing to do with the dash gauges working. There is a check engine light, I have read the codes, and the car is not running right.
post #9 of (permalink) Old 07-28-2003, 09:09 PM
anyone?
post #10 of (permalink) Old 07-28-2003, 09:24 PM
If the TPS reads bad, than replace it.
I went through water that I probably shoudnt have and I fried the TPS.
From what I know its a realatively sensitive componant. Replace it, see what happens.
My symptoms where erratic idle, misfire on acceleration, and BAD GAS MILEAGE.
easy fix, and i siliconed the heck out of it. now hopefully i wont have problems the next time i cross water that i shouldnt
Phil
newbie24x4 is offline
