Re: 35\" or 37\" tires?
I have seen only bad things from roickcrawler.. including posts here about the horrible customer service... crappy workmanship is one thing, but bad customer service is inexcuseable.
I have a RE long arm kit. its the very first kit they ever sold and it has 2 worn joints.. funny though.. they are the solid rubber mounts that wore, not the shperical ends. This kit has LOTS of off road miles on it and I drive it every day to work. it also ramps 1270 on a 25 degree ramp..thats falls into the "wayyyy pleanty" category.
I was hoping to run 37" tires but they might be a bit much for that little straight six.
not with 5.18 or 5.38 gears. I run 5.38's with 37" mtr's. 2700rpm at 65mph in 5th gear of an nv4500....the 4.88's might be perfect, but I like the loewer gears....and i dont drive on the highway a lot.
I have already done the warn conversion with my front outer so I am not real concerned about breakage
your still only going to have x297 joints up there...37's will snap them. 35's can too
why did you start with a rubicon?
