Re: Moving Gas Tank!!
Deadly choice,,,,but if you must,,,,check to make sure that if you roll the Jeep and it stays upsidedown that there is no way for the gas to leak/drain. I would hate to see you get covered in gas around a hot engine while you buddies try to unbuckle your seatbelts,,,or in fact an officer at the scene of a accident. Double clamp all flex lines, vent the low spot of the tub. Gas fumes from filling the tank could sit in a low spot in the tub. On a calm air day, you are making a perfect bomb. The explosive power from the vapor of a few spoonfuls of gas equal one stick of TNT...Go on line to the Goast Guard and look at some boats that had a few drops of gas collect in a low spot....
