Need help now!!! w/steering stab replacment - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-20-2003, 05:42 PM Thread Starter
babypoo's Avatar
Location: Milwaukee(which is algonquin for the good land)WI U.S.A
I think my steering stabalizer is gone to to the feriuos shaking I would get after hitting a bump...I went out and bought a new and began to remove the old one. Where I;m having the problem is the stud that holds the steering stabilizer to the tie rod te castle nut came off but the stud will not push out!!! I have tried P.B. Blaster, heating it with both propane and mapp gas and pounded on it with my BFH but to no avail it will not even move. Any help will be more than apprecited maybe a ball joint spliter??? I just don't know.
John
[email protected]
babypoo is offline
post #2 of (permalink) Old 07-20-2003, 05:54 PM
Rio_Grande's Avatar
Re: Need help now!!! w/steering stab replacment
Can you press it out with a vice and a socket just big enough to clear the head of the stud? Bet once you got it going it would pop right out.
Rio_Grande is offline
post #3 of (permalink) Old 07-20-2003, 06:08 PM Thread Starter
babypoo's Avatar
Jeff thanks for the quick response,
If I were to use a vice I would have to remove the steering linkage would maybe a c-clamp work?
John
[email protected]
babypoo is offline
post #4 of (permalink) Old 07-20-2003, 07:03 PM
Rio_Grande's Avatar
Maby, same principal. but if you press on the bolt, make sure and use a nut or brass on the bolt thread.
post #5 of (permalink) Old 07-20-2003, 07:05 PM
Rio_Grande's Avatar
I looked at mine, You may be better off with a ball joint seperator or mabey even a pitman arm puller.
post #6 of (permalink) Old 07-20-2003, 08:30 PM Thread Starter
babypoo's Avatar
I ended up using an air chisel to make a pilot and the then a tie rod puller...popped right off now as I was putting it back together I come to find out that the steering stabilizer isn't even the problem Dohhh!!!!! Back to working on it tomorrow I migt go get parts tonight.
Thanx a ton Jeff,
John
[email protected]
babypoo is offline
post #7 of (permalink) Old 07-20-2003, 08:33 PM
mav750's Avatar
Check the front track bar John. Ive been seeing alot of those goin bad at work, and causing the same thing.
mav750 is offline
post #8 of (permalink) Old 07-20-2003, 08:43 PM Thread Starter
babypoo's Avatar
Track bar goes from pitman arm to tie rod... correct, if so the ball joint in the end that connects to the pitman arm is the culprit can just that ball joint be replaced?
John
[email protected]
babypoo is offline
post #9 of (permalink) Old 07-21-2003, 10:47 AM
barfnick's Avatar
I don't believe so. I think it is the same setup as my XJ and I ended up having to get a new one. As a side note, don't go with the cheap one 4WD hardware sells. It probably works fine without a lift, but I bought one and it lasted all of 3000 miles with my 3" lift. If you have a lift, get the adjustable one.
barfnick is offline
post #10 of (permalink) Old 07-21-2003, 03:24 PM
<font color="blue"> drag link </font color> goes from pitman arm to tie rod
speed_buggy is offline
