TR upgrade, Help, wont start - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-20-2003, 04:54 PM Thread Starter
Aaron871's Avatar
Alright, so I took my distributor out, installed the new one. Hooked up the new ignition module and the new coil. Turns over but wont fire. I have spark at the coil, but not at the spark plug wires. [img]images/graemlins/confused.gif[/img]
This is going into a 1975 304 so it's not a plug and play install.
Aaron871 is offline
post #2 of (permalink) Old 07-20-2003, 05:05 PM
GeeAea's Avatar
Re: TR upgrade, Spark at coil but not at plugs
You didn't forget to put the rotor in did you??? [img]images/graemlins/confused.gif[/img] That should be the only thing between the coil and the plugs. You would not be the first to overlook this (but you might be one of the few to admit it [img]images/graemlins/blush.gif[/img] )
GeeAea is offline
post #3 of (permalink) Old 07-20-2003, 05:13 PM Thread Starter
Aaron871's Avatar
I think it's all there. The distributor, the button (that thing that spins), a spacer, and the cap.
Aaron871 is offline
post #4 of (permalink) Old 07-20-2003, 05:29 PM
Swansonoldcj
I understand it's all there! but put in a new rotor (the thing that spins). and look at the inside of the cap for any carbon tracks or bad moulding lines. and if that doesn't work swap the leads to your coil primary side.
[img]images/graemlins/RockOn.gif[/img]
gas.
post #5 of (permalink) Old 07-20-2003, 05:38 PM Thread Starter
Aaron871's Avatar
it's all new stuff....all of it.....I had to make a wiring harness because that stuff dosen't plug into an older harness....... I'm guessing I didn't wire it correctly... ..the ignition module is hot to the touch..
Still has spark at the coil and none at the plug wire...the rotor is spinning....
Aaron871 is offline
post #6 of (permalink) Old 07-20-2003, 05:46 PM
GeeAea's Avatar
Somehow I think that your rotor is not close enough to the center post on the cap. IF you have spark coming out of the coil wire the ROTOR is the only thing between it and the spark plug wires.
Humor me. take the cap off and measure the height that the rotor is off of the base (the part the cap rests on) of the distributor. Then measure the interior depth of the cap. There should be very little difference in these two measurements.
GeeAea is offline
post #7 of (permalink) Old 07-20-2003, 05:52 PM
Swansonoldcj
Take the rotor off and look at the inside of it, where it slides on dis. shaft and look for any discoloration. if you see any replace it! if not swap the small wires on the coil terminals! If they are reversed the coil may still spark lightly but you increase the resistance in the whole cicuit tenfold! thus the hot module!
gas.
post #8 of (permalink) Old 07-20-2003, 06:08 PM Thread Starter
Aaron871's Avatar
OK, good call. I reversed the coil wires, way more spark at the coil, much cooler ignition module.
The measurements lead me to believe that I am falling just short of making a connection, after switching the wires I have a very light spark at the plug wires. Very light!
Is there suppose to be a spring under the rotor?
Aaron871 is offline
post #9 of (permalink) Old 07-20-2003, 06:23 PM
Swansonoldcj
The center button in the dist. cap may be spring loaded, or it will depend on the center contact of the rotor to keep presure on the contact. are the cap and rotor from the same manafacturer?
have fun and smile; it's a jeep thing!
gotta take the kids to MD'S. good luck...
gas.
post #10 of (permalink) Old 07-20-2003, 07:10 PM Thread Starter
Aaron871's Avatar
I'm getting a light spark at the plugs. My ignition module is too hot to hold on to, even if I switch the coil wires.
Did I wire it wrong????
Distributor-
Black to black w/ green in ig. mod
Black w/ red to orange in ig. mod
Violet w/ black to Violet in ig. mod
Ignition module-
Red to coil pos
Dark green to coil neg
White to power
anyone know anything about this?
Aaron871 is offline
