gauges on the fritz - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-17-2003, 10:34 PM Thread Starter
Journeyman
gauges on the fritz
Hello
I currently have an 83 CJ7 with a 360 swap. My current issue are the temp and fuel gauges. I have read the article in the Electrical tech section. Right now I am currently reading a steady 12 volt on the middle posts, instead of the pulsed 5 volts. Both sending unit check out with appropriate resistances.
My question is, has anyone ever put a steady 5 volts there instead of the pulse? Will either work? I cannot think of a reason it has to be pulsed, except that a steady 5 volt could potentially burn the gauge out. Has this been done before? Any help would be great
JeepStud is offline
post #2 of (permalink) Old 07-18-2003, 10:07 AM
Re: gauges on the fritz
Read the article again ... twice ... and preform ALL the ohm tests on the gauges.
An external regulator or diode feeding the 5 volts will work.
You still have to do the ohm reading tests on the fuel and temp gauge pins for proper resistance. If they check out, chances are the meters are good though you may have to dissemble the fuel gauge and buy pass the old bi-metalic pulse regulator if it is cooked.
Jaffer is offline
post #3 of (permalink) Old 07-18-2003, 10:21 AM
1. John's correct (as usual).
2. JCW does sell a 6 volt regulator,
3. It's used to supply 6 volts to gauges,
4. The cost is about $18
5. Or, Try this one...
