Re: Re-machine Model 20?
is it too badly worn to stick woth some of that green permatex bearing goo stuff?
maybe you could knurl the surface to hold the race tight?
is it the inner bearing race?
or the outer?
im not real clear on where the damage is, but IM nos treal fameilar with after market axles either.
maybe you could get a bearing with the same OD but a slightly smaller ID, and have the axle machined down a wee bit smaller to a good press fit again?
should cost peanuts if you can find a small lathe around, and then spend a few minutes with a bearing book
