-   -   my cj5 has drum brakes all 4 (https://forums.off-road.com/jeep-short-wheelbase/171181-my-cj5-has-drum-brakes-all-4-a.html)
Dex 07-14-2003 03:23 AM
im about to tackle brakes and lines to see what might need replaced, it does have a porpition valve on brake lines at master cyl. how can i check or get a new one and are they all the same???? [img]images/graemlins/RockOn.gif[/img]
Pigpen 07-14-2003 07:59 AM
Re: my cj5 has drum brakes all 4
I thought disks were standard in 77? Either way you should have a proportioning valve mounted on the inside of the driver's frame rail to the left of the tranny bellhousing. Do not bother trying to do anything special to the prop. valve. Just make sure you use the correct tool to press/pull the little button while you bleed the brakes. If you encounter any problems cut the damn thing off and add an adjustable prop valve for $40 from Summit or somewhere.
sammi_davis 07-14-2003 10:25 AM
While your doing brakes I would try and find a cheap disc setup for the front . I hate the drums on the front of my cj 6 . I have to adjust them quite a bit to keep them from dragging me left or right across the road . I have all the stuff to swap to discs ...I just dont have the time .
304CJ7 07-14-2003 03:33 PM
When i bought my 72 CJ5 the brakes were worthless. You downshifted to stop. All i did was bleed them and take them apart cleaning them and replacing pads and now they are awsome for drum brakes. It will even skid now. You might try this route but if youve got some cash upgrade axles.
M38 07-15-2003 10:03 AM
Post a pic.
It sounds like your saying your prop. valve is screwed right into the master cylinder if so it's like mine and old
mine is nothing more than a "tee" one line going to the rear and one to the front just like the ones that divide the fluid on the axles
take some good pics. and these guys will be able to identify almost all of it.
M38 07-15-2003 10:04 AM
Post a pic.
good luck
Clint
woops clicked twice
