Coolant draining is a mess!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-24-2003, 12:05 PM Thread Starter
Lately I have been doing some cooling system work, including draining and re-filling a few times.
But it's a mess! The bottom of the radiator has a plug, and when you take it out, the coolant comes RUSHING out and gets everywhere.
Does anyone have any ideas on how to better drain without a mess?
I make a huge mess every time I need to change the thermostat for example.
pnut is offline
post #2 of (permalink) Old 06-24-2003, 12:14 PM
Re: Coolant draining is a mess!!
You're saying you have a plug? Like similar to an oil drain plug, but smaller? Mine (and all I've seen) has a petcock .. basically a threaded in-line valve that sorta looks like a wing nut. Place a bucket underneath & twist to open .. no muss, no fuss. I think you can even connect a small diameter plastic tube over the end to better direct the flow if needed. If this isn't your setup, take the plug you have to a parts house or radiator shop & get a petcock of the same thread size. HTH.
ff0758 is offline
post #3 of (permalink) Old 06-24-2003, 12:16 PM
Get a petcock with a stem that you can slide a hose over to relace that plug.
in2mud is offline
post #4 of (permalink) Old 06-24-2003, 12:26 PM
1. Yeah, this post has kind of confused me too...
2. I've never seen a radiator with a plug,
3. And NO petcock.
4. That fun <font color="red">HELP</font color> rack at your autoparst store has replacement petcocks.
5. I like In2mud's idea... infact I may use it,
6. It always seems like even with a petcock,
7. That engine coolant always dribbles everywhich way,
8. Except into the drain tub.
9. I gotta think about this one.
post #5 of (permalink) Old 06-24-2003, 12:43 PM
ecamp55's Avatar
Lirpasues CJ also has a plug and no petcock.....kinda a plastic wingnut lookin thingy. I've have the same thing on other vehicles of mine too.
ecamp55 is offline
post #6 of (permalink) Old 06-24-2003, 02:09 PM
I have a special hose in my tool box I made up just for this because it can be hard to find hose that fits them. So I took a old GM spark plug boot (long straight HEI style plug end the kind that usually have the metal heat shields) then attached a 2 ' piece of hose to that. The plug boot streches easier then most hose and is also a whole lot easier to push on and get back off.
in2mud is offline
post #7 of (permalink) Old 06-25-2003, 06:44 AM Thread Starter
Thanx all. Yes I do really have a wing nutted plug.
Does someone know the (male) thread size of the threaded hole at the bottom of the radiator where I will put this petcock valve?
pnut is offline
post #8 of (permalink) Old 06-25-2003, 07:11 AM
babypoo's Avatar
Location: Milwaukee(which is algonquin for the good land)WI U.S.A
For all fluids you can use an old garbage can lid poke a bunch of drain holes in the center of it and place it over your catch pan. Works real good much larger catch area, I think I read about it in "cheap tricks"
John
babypoo is offline
