Cant get into 4 high help! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-24-2003, 02:08 AM
last night I almost got stuck in a pond cause I couldnt get into 4 high. It would go into 4 low though whats the deal??? [img]images/graemlins/confused.gif[/img]
post #2 of (permalink) Old 06-24-2003, 04:52 AM
jdoggmoney's Avatar
Re: Cant get into 4 high help!
Have you ran in 4 high since the body lift? Maybe check for clearances. Often times body lifts cause tranny and t-case shifting problems. Good Luck! [img]images/graemlins/grin.gif[/img]
jdoggmoney is offline
post #3 of (permalink) Old 06-24-2003, 07:33 AM
Vacuum hoses perhaps?
post #4 of (permalink) Old 06-24-2003, 07:59 PM
hey guys I just realized that after I did the body lift I got a pop in my steering while turning. I also just figured out that I cant get into 2 high not into 4 high I think I might have been in 4 high the entire time. now I am wondering if I have been in 4 high the entire time since the body lift, if so please tell me what to do.
post #5 of (permalink) Old 06-25-2003, 05:21 AM
jdoggmoney's Avatar
I agree with penny. Once you get all the binding and shifting problems from the body lift fixed, check the vacuum hoses to the 4x4. Depending on how long you've been driving it and rather the hubs were locked in, you may have damaged something, but you most likely would have heard this happening I think. Good Luck [img]images/graemlins/grin.gif[/img]
post #6 of (permalink) Old 06-25-2003, 07:28 AM
Vacuum hoses on an 84 CJ7 shouldn't have anything to do with the 4wd actuation. Check to make sure that your t-case shifter isn't hitting against the transmission tunnel; you will probably have to get creative with a Sawsall.
Ken Linzmeyer
greencj7 is offline
post #7 of (permalink) Old 06-26-2003, 05:55 AM
Journeyman
MTurner00's Avatar
Mine wont shift into 4hi since I swapped out the T5 for the T176 tranny...it has moved it in the transmission tunnel back just enough to where it hits the metal before engaging in 4hi...my problem with the idea that yours is doing the same thing is that if you have the dana 300 xfer case, 4hi is on the bottom with 2hi above it, then neutral, then 2hi at the very front....so if you have been running in 4hi, and you can get it in 4lo....that means you have to pass right through 2hi. Unless you have some other xfer case in there, in which case I have no idea. [img]images/graemlins/grin.gif[/img] Anyhow, the setup on the 300 is like this:
4lo |
2hi |
N |
4hi |
Good luck!
MTurner00 is offline
post #8 of (permalink) Old 06-26-2003, 09:07 AM
jdoggmoney's Avatar
Oops! I could have swore I checked the bio before I opened my big mouth. Greencj7 is right, don't go lookin for vacuum lines under there... you wont find any! [img]images/graemlins/thud.gif[/img]
post #9 of (permalink) Old 06-30-2003, 11:57 PM
sorry I that I didnt reply sooner guys but I already figured it out you were right after all I was a moron and thought I was in 4 high but after all I was in 2 high and my heat sheild is blocking the shifter. Now all I have to do is a little cutting. I fixed my steering as well. Thanx guys alot.
