HELP! Wont start? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-23-2003, 12:08 PM
jonestown
HELP! Wont start?
Ok here is my problems, last week I was getting spark and fuel but would'nt start so I replaced the dist cap, rotor and coil that fixed the prob. then no fuel so I replaced the fuel pump fixed that prob. Then this morning started fine ran great stopped at a store when I came out it would'nt start. What is going on? I'm going at lunch to see whats going on. Any ideas? Suggestions? Need this to go away being my DD and I have my daughter all week. Thx in advance. Eric [img]images/graemlins/thud.gif[/img]
post #2 of (permalink) Old 06-23-2003, 12:22 PM
Re: HELP! Wont start?
1. Well, it's got to be something.
2. We gotta start somewhere.
3. So which don't you have?[*]Timing [*]Spark [*]Fuel?
post #3 of (permalink) Old 06-23-2003, 12:26 PM
84_CJ7's Avatar
Ignition control module? Not turning over? Turning but no fire? Are you still getting gas? Still getting spark? Flooded? Choke? It could be something as simple as a bad ground or a short. Can be tough to find. On a Jeep that ignition control module will let you down at the worst times. May want to pick one up - it's good to have a spare around.
Good luck and keep us posted on the mystery illness.
Scott
84_CJ7 is offline
post #4 of (permalink) Old 06-23-2003, 01:10 PM
jonestown
Ok I went and checked at noon now I dont have spark. I forgot to post earlier but this is a 75 cj 304 with the GM HEI dist. Could Auto Zone gave me a bad coil or is something else shorting it out. Im stuck. HELP me out here brothers.
post #5 of (permalink) Old 06-23-2003, 01:27 PM
84_CJ7's Avatar
Do you have power to the coil? If you have power to the coil and no power to the plugs you may have isolated where the problem is but now you need to find what is causing it. I would really check my wires over good for cuts, breaks or buildup at connectors. I would also check for good ground. My CJ horn quit working and all it took was reseating the ground/attaching screw. That simple. Hope it's something that simple for you.
Scott
84_CJ7 is offline
post #6 of (permalink) Old 06-23-2003, 01:30 PM
1. The GM HEI grounds through the distributor body, to the engine block.
2. If the grounds are bad... [*] Dist body to engine ground[*] Engine ground to negative battery post
3. You'll get no spark.
4. Pull the ignition module at the base of the distributor and have it checked.
