more about the dana44 axle bearing mystery.... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-22-2003, 11:26 PM Thread Starter
jeepnut_nh's Avatar
ok....4wd hardware swears up n down that the axle bearings they r sending me r for my dana(reference the bill of materials), so that part of my issue should turn out ok
anyways, after replacing all the bearings on the carrier and pinion, i figured id install those into the pumpkin while i wait for axle bearings......
install went ok, pattern look acceptable on the gears, and i understand it may be a bit hard to turn with little lubrication, but it seems to spin fairly freely about 1/2 a rev and the other half rev requires about twice as much effort
i havent put the dail indicator on it yet (i need to "borrow" one from work...lol) but i cant really "feel" any backlash....
the meat of the question is how easy shold the assembly turn by hand when spinning the yoke?
and...yes...i realise i should have done a full rebuild but murphy (read that "the State of New Hampshire inspection regs) mandated the axle seals be replaced now and as many Jeep owners know....Just Empty Every Pocket........ [img]images/graemlins/wink.gif[/img]
jeepnut_nh is offline
post #2 of (permalink) Old 06-22-2003, 11:54 PM
Re: more about the dana44 axle bearing mystery....
It shouldn't be binding up, that's for sure. You really need to check the backlash.
The_Bishop is offline
post #3 of (permalink) Old 06-23-2003, 12:10 AM
1. What's the gear pattern look like?
post #4 of (permalink) Old 06-23-2003, 01:52 AM Thread Starter
jeepnut_nh's Avatar
thanks for the diagram leve....its actually pretty darned close to that pic, spoke to another mechanic here at work, he says when tightening pinion i should gently spin the wheels as i torque it down, so i guess ill wait for the axle bearings and redo it again.... [img]images/graemlins/tongue.gif[/img]
ill post how it goes...bearings should get here in the next couple days
thanks for the advice all......
post #5 of (permalink) Old 06-23-2003, 07:44 AM
It bothers me that there is a difference half way around. You didn't say whether it was a half turn of the pinion gear or a half turn of the ring gear, so I can't suggest what to look for. I fear that it won't last long if you run it that way.
Jim_Lou is offline
post #6 of (permalink) Old 06-23-2003, 10:29 AM Thread Starter
jeepnut_nh's Avatar
yes, thats what really concerns me, hopefully when i put the axles in (after relieving any stress in the carrier) and carefully tourque things up it will turn out that the bearings needed a little more tlc on the install.....
so i continue my vigil for the UPS guy!
btw it seemed to be about half of the ring gear....
post #7 of (permalink) Old 06-23-2003, 04:15 PM
i rebuilt a D35 for a friend that had a similar problem.
backlash was OK half-way around...then it would tighten up so it took about twice the effort.
i checked the pattern and the pattern seemed to change too. i attributed to used (and abused) gears. i filled it up with lube while on the axle stand and it immediately started dripping about 1 drip every minute.
so, i thought i had the seal in crooked. i then started looking more closely at it and realized the pinion was bent. i then threw a dial-indicator on the sealing surface of the yoke and found it did have some excessive runout. then, i pulled the pinion back out, put it on a surface plate with some v-blocks and a dial-indicator and found it was bent about 0.020" in the center causing my problems. i decided it wasn't worth messing with and we bought some new gears.
matt
jeepnmatt is offline
post #8 of (permalink) Old 06-23-2003, 06:20 PM
If you had the ring gear off the carrier you might have gotten a burr or small piece of debris under it.
Jim_Lou is offline
post #9 of (permalink) Old 07-05-2003, 11:42 PM
I Do This For The Glory
JEEPN's Avatar
I have seen this happen, but it's always been due to little/no lubrication, as soon as I filled it and worked everything around, it was fine.
Did you find out what it was?
JEEPN is offline
