smelling gas - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-22-2003, 08:24 PM Thread Starter
smelling gas
I recently purchased my first jeep, an '84 CJ-7, 258 with Howell fuel inj, (I've driven Toy trucks for 20 yrs). While driving on a country hwy with top off I began to smell gasoline. I pulled over and checked TBI and ALL fuel and return lines and found no obvious leaks. Following my nose, the odor is strongest behind filler, I opened cap and small amount of fuel (maybe 1cc) dribbled out. Could this be a problem with injector return? evaporator? cap? or something else?
thanks
Scott
holsters is offline
post #2 of (permalink) Old 06-22-2003, 08:26 PM
Re: smelling gas
Possibly the cap, also make sure that there are no rust holes in the filler neck.
xj_kid is offline
post #3 of (permalink) Old 06-22-2003, 08:42 PM
Re: smelling gas
1. Welcome to the forum.
2. Please complete your user profile:[*] It's a nice thing to do.[*] It's helps to know who we're talkin' to.[*] It helps to know what's your ride.[*]It helps to know the local in which you live.
3. Read the New Posters Message at the top of the forum.
4. Participate! Two brains are better'n one.
5. The return gas line is under pressure,
6. I'd look for the leak in one of three places...[*] Where the lines go over the frame crossmember,[*] In the flexible lines from the hard lines to the sender/vents.[*] The gas tank seams.
7. You didn't mention where the filter was installed.
post #4 of (permalink) Old 06-22-2003, 09:11 PM Thread Starter
Re: smelling gas
The odor's not at the "filter" but at the filler neck/cap area. The filter is just behind elect pump just for'd toe T case. No odor there.
holsters is offline
post #5 of (permalink) Old 06-22-2003, 11:29 PM
Re: smelling gas
1. Well, I'd still drop the tank,
2. Examine the seams,
3. and the felx lines...
4. You may have pinholes in the tank...
post #6 of (permalink) Old 06-23-2003, 06:34 AM
ecamp55's Avatar
Re: smelling gas
I'd take a hard look at the rubber lines from the tank to the steel lines. I'm going thru that with my 84 Ford pickup....rotten lines.
ecamp55 is offline
post #7 of (permalink) Old 06-23-2003, 05:52 PM
Re: smelling gas
I have a minor leak on my '74 CJ5. It is right where the filler goes into the tank. There are two hoses, and it is the smaller, vent hose inlet that is leaking. Since the tank on this rig is a PITA to remove, I tried stuffing gas tank fix epoxy up in there the best I could. It mostly worked. I only smell gas when at completely full. I figure to replace the tank this winter with a larger capacity poly tank. Anyhow, I would check the filler and vent hoses, and their inlets into the tank.
cj5_pilot is offline
post #8 of (permalink) Old 06-23-2003, 06:05 PM
sourpwr's Avatar
Re: smelling gas
I too have an '84 CJ7 with the Howell TBI. I had gas leaks at the Trottle body and then in the small diameter "soft" lines on the top left side of the gas tank. If you have allready checked the TBI, I would check all of the "soft" lines before dropping your tank.
Mike
sourpwr is offline
post #9 of (permalink) Old 06-24-2003, 10:20 AM
Re: smelling gas
I was smelling gas last year near the fuel tank of my 84 CJ-7, and turned out to be similar problem to the one cj5-pilot described. There was a leak where hoses go into top of tank, and I only smelled gas when tank was full and sloshing around near the top. Could be the smell is coming from closer to the tank versus top of the filler?
chrispchang is offline
post #10 of (permalink) Old 06-24-2003, 10:33 AM Thread Starter
Re: smelling gas
I havn't drooped the tank yet. I'm waiting till it's closer to MT. The odor is up inside the R rear corner of the tub, and is gone now that the tank is half MT. So its probably at the top of the tank at filler tube or vent or any of the other connections at the mouth. When I drop the tank (probably next week) I'll let you know want I find. The stock skid plate has been crashed so it could easily have broked a solder joint in one of the small tubes on the tank cap. (Happened once on my wife's suburban).
Thanks for all the tips. I'll let you know what I find.
holsters is offline
