TJ mileage - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-21-2003, 10:45 PM
TJ mileage
I recently purchased a 1997 jeep TJ, with 4.0 liter 6cyl. engine and automatic transmission. The odometer is currently reading 62,000 miles and the motor was recently tuned.I am running 32-11.50- 15 LT tires(inflated at 35 p.s.i.) the vehicle is otherwise stock.I am averaging 155 miles per tankful,(city) considering it has a 15 gallon gas tank ,this equals to a little more than 10 miles to the gallon. This seems like terrible mileage for a six cylinder vehicle.My question is this: Is this mileage normal for this vehicle or is their some miscalculation in the odometer due to the oversized tires and if so how do I recalculate the mileage taking into account the larger rubber.What upgrades are on the market to better the mileage on the new TJ wranglers.
post #2 of (permalink) Old 06-22-2003, 12:57 AM
babypoo's Avatar
Location: Milwaukee(which is algonquin for the good land)WI U.S.A
Re: TJ mileage
That's alot of air pressure even for street pressure I run between 25-27# but that won't help your gas mileage. O.K. to answer your first question... yes it does affect your speedometer and your odometer, the only way I know of recalibrating it, is Superlift and one other manufacturer(can't remember the name) make a speed sensor calibrator. JC Whitney sells the Superlift brand one for $179.95, part #AKB487486Y. Second question... I have a 4cyl with 32's and that's about the same mileage I get(per mile I have a larger tank). What gears do you have and do you have a manual or auto tranny? The three speed auto if you have it is not helping matters either. Third Question...There are multiple things you can add to your Jeep to help fuel mileage (or so the adds say) I installed a TB spacer on mine and noticed a minor difference that's about the only thing I've done that is supposed to help. But if you put a post up I'm sure others will have suggestions.
Hope this helps,
John
[email protected]
babypoo is offline
post #3 of (permalink) Old 06-22-2003, 01:40 AM
Re: TJ mileage
Good greif that is much worse than normal. My Bro-in-law's stock 97 TJ with a 5-Speed has a range of almost 300 miles in mixed driving any my heavily modified YJ with a 5-Speed can pull down 260 miles in mixed driving.
If your tranny isn't shifing crisply, your torque converter might be slipping enough to waste a whole lotta fuel.
Try a complete tranny fluid flush and put in some synthetic (Mopar approved) ATF in it and see if the mileage improves.
BTW the estimated stock fuel consumption for your year is 17city 19highway for comparisons sake.
Give Advance Adapters a call to find the correct speedo gear straight from Mopar. Thy have several options for the NP232 T-Case. They usually run about 12 bucks.
Hope this helps
post #4 of (permalink) Old 06-22-2003, 01:47 AM
babypoo's Avatar
Re: TJ mileage
He's calculating his mileage off of the odometer which is also offset by the larger tires. His true fuel mileage is better than he's saying.
John
babypoo is offline
post #5 of (permalink) Old 06-22-2003, 01:50 AM
jamgood96's Avatar
Re: TJ mileage
35psi is way too high to be running. That's probably what the recommended max pressure is. I run 24 on the street in my '93 YJ. Try dropping it to around 26-28 or so. As for your MPG you're getting, like said, you need a new speedo gear. There are a couple of online sites that will help you figure out how many teeth you need on your new gear to correct your speedo. Here's one I found on a quick search. Hope it helps.
Speedo Calibration
As for what you can do to up your MPG, I'm not really sure what can help you in that department. There are plenty of mods to do to the motor, but most are performance mods, and may or may not help your MPG. I'd say slap on a throttle body spacer for starters, and maybe upgrade to a K&N filter. Also, keeping your foot out of the skinny pedal is a sure way to help with the MPGs.
jamgood96 is offline
post #6 of (permalink) Old 06-22-2003, 08:17 AM
GeeAea's Avatar
Re: TJ mileage
Here are some more.
These sites do not all agree. Keep in mind that some of them may be calculating as though the tire was measured as labled (i.e. a 33" tire is rarely 33" etc.) Also the dealer tells me that there are no odd # gears between 32-36 or 32-38. If you need addtional adjustment the dealer can use the DRB2 scanner to correct the speedo further ...or they can do the whole thing without a gear change.
You've got issues beyond speedo error. You should also have a 19 gallon tank. The 4.0 with an auto around town will be a gas hog. Heck my daughter gets our SE down to 12.5 mpg (it's a 4 cylinder). She manages to challenge V8s for economy. I imagine that the 4.0 would be slightly worse.
Heck ..you're in BIG BLOCK range ...but I'd have a hard time imagining the thing consuming that much fuel without some apparent operational problem (like a Check Engine Light).
Ah!!! The 97 should have the on-off-on-off-on key thingie diagnostic feature. These codes should work for you.
GeeAea is offline
post #7 of (permalink) Old 06-22-2003, 07:28 PM
Re: TJ mileage
1. Welcome to the forum.
2. Thanks for filling out your user profile.
3. Read the New Posters Message at the top of the forum.
4. Participate more often!
5. Two brains are always better'n one!
6. You may want to think about:[*]Air input upgrades [*]Freeflow Exaust
7. Even with miscalculation... the mileage seems low.
post #8 of (permalink) Old 06-22-2003, 09:02 PM
Re: TJ mileage
The 97 was the first year of OBD II so the on- off- on- off thing doesnt work, go to autozone for a free diagnostic.
as for the mileage, its all how you drive it!!! I live in Michigan and the speed suggestion is 70mph, which means if you go slower than 75, you get run over. Well, most of my driving on road is on the highway, those four angry squirels under the hood want lots of go juice when you work the engine that hard. I am lucky to get 18mpg. That is stock. Not good. I run a K&N air filter too. The people I know here with 4.0's get roughly 14-15 mpg. There are MANY factors that affect fuel economy.
How much ethanol does your state require in the gasoline, temperature, etc.....
Phil
newbie24x4 is offline
post #9 of (permalink) Old 06-22-2003, 09:38 PM
GeeAea's Avatar
Re: TJ mileage
Are you sure about that? I've had this debate before. In fact before I learned that OBDII was adopted in 96 ..I argued that the 98 was the first OBDII because soooooooo many 97 owners had used the on-off-on-off-on feature. Hence I assumed that this was not OBDII since it shared the same flash codes as earlier OBDI vehicles.
So is this "true knowledge" ...or just assumed (like mine was of 97s being OBDI)????
GeeAea is offline
post #10 of (permalink) Old 06-22-2003, 09:45 PM
Re: TJ mileage
Well I have a 97 and it has OBDII, Not sure if it was adopted later in the year, or if you can do both? But I KNOW that I used the OBDII to diagnose my Jeep.
Phil
