Setting Timing - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-20-2003, 05:48 AM Thread Starter
84_CJ7's Avatar
Setting Timing
This all started with what I thought was timing and really was a bad fuel pressure regulator. What is the simplest way to check my engine speed while setting my timing? I don't have a tach on my CJ 258 (no ECU) and with the Weber and the TFI upgrade I'm either pinging at high speed or dieseling at shut-off. And what is the optimum setting for this setup? I have seen 6 BTC and 9 BTC (factory). What degree should the timing move to after the vacuum advance is hooked back to the distributor? I can't remember ever having such a hard time setting timing!
Scott
84_CJ7 is offline
post #2 of (permalink) Old 06-20-2003, 07:22 AM
Re: Setting Timing
Regardless of what might be the "optimum," the timing in your engine now is too far advanced, assuming that you don't have some other problem such as carbon buildup, lean mixture or third-world gasoline.
You can probably get a cheap test tachometer, but shouldn't really need one. Set the engine down to a reasonable-sounding idle and set the timing. See how it runs. Then repeat as necessary.
My 258 likes anything from about 2 to 10, although it will ping at the higher end of the range, and loses power at the lower end. Generally engines run best with timing just below the pinging threshold.
Just retard it a few degrees at a time until the pinging goes away. That will probably solve the run-on too. If it doesn't, the mixture probably is too lean overall.
Jim_Lou is offline
post #3 of (permalink) Old 06-20-2003, 08:09 AM Thread Starter
84_CJ7's Avatar
Re: Setting Timing
I had been doing it by ear. I have always set my old Ford pickups in that manner and never have any problems. Run like a top. I think I got the CJ too out of whack trying to compensate for a bad regulator and was wanting to return to some solid ground from where I could justify any moves that I made. Your post makes good sense and was what I was doing before I decided to do it "right". Just getting frustrated. Thanks.
Scott
84_CJ7 is offline
post #4 of (permalink) Old 06-20-2003, 12:43 PM
Re: Setting Timing
On most older (higher mileage) engines I've found that they need to be timed a couple degrees in advance of what the book calls for. Usually I just time them by ear. Not the most scientific method, but they have always run better then if I just set them to book spec and go.
cj5_pilot is offline
