clutch questions?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-19-2003, 03:12 PM Thread Starter
clutch questions??
i did a search and didnt come up with too much, how hard is it to replace the clutch linkage on a 83 CJ7 with the t-5 tranny. I figure i might as well replace the clutch as it is at least 10 years old. What all is involved in replacing the clutch and clutch linkage? is there any special tools i need or should i just have someone put it in for me?
ClassicRockCJ is offline
post #2 of (permalink) Old 06-19-2003, 03:33 PM
ricochet's Avatar
Re: clutch questions??
I say do it yourself. Your basic hand tools will do just fine. The only thing you have to make sure of is that your new clutch will come with an alignment tool. This keeps the clutch centered while assembly. Here is what a brief list of things that have to be done. (I may forget something)
1. Disconnect your battery
2. Remove your starter.
3. Put jack under tranny and remove crossmember
4. Disconnect your front and rear driveshaft from your transfer case.
5. Remove shifter
6. Remove transfercase
7. Disconnect any linkage attached to your bell housing.
8. Remove your transmission. (you might get away with just pushing it back).
9. Remove clutch and throwout bearing
10. Have flywheel resurfaced
11. Reassemble.
Remember to keep all your bolts labled where they came from. It will make it easier and faster when putting it back together. As far as which clutch to get, if you run alot of mud and water, I suggest you get a 3 finger clutch (has less of a chance to get packed and jammed. But for just all around wheeling, your stock replacement will be fine. As far as your clutch linkage is concerned, I don't know if you have a mechanical or hydrolic. If hydrolic, I would replace the line. If it is mechanical, I would replace the whole assembly. You can check out Hagars 4WD for your clutch needs. He even has a breakdown of your clutch linkage at the bottom of the page
ricochet is offline
post #3 of (permalink) Old 06-19-2003, 08:28 PM Thread Starter
Right now i can only afford to replace the clutch linkage is this a good idea or should i wait to replace the whole thing
