Electrical mystery... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-18-2003, 04:57 PM
FrenchJeeper
Hello,
Tonight i have noticed i didn t have any gauge light anymore and no more position light too. I replaced the fuse and the bulbs but it didn't change a thing... Do you have any clue about where i should look at???...
Thanx
PS:if you have the 1989 YJ fuse box schema i would love to see it!!!...
post #2 of (permalink) Old 06-18-2003, 05:14 PM
NIX
NIX's Avatar
Re: Electrical mystery...
I once had a cracked fuseholder, so the fuse was held by only one post, not connecting anything. I discovered after poking in the harness for 2 hours.
NIX is offline
post #3 of (permalink) Old 06-18-2003, 06:23 PM
babypoo's Avatar
Location: Milwaukee(which is algonquin for the good land)WI U.S.A
Do you have power coming into and leaving the fuse???
John
babypoo is offline
post #4 of (permalink) Old 06-19-2003, 12:57 AM
FrenchJeeper
Thanx...
Do you know where i could find a schema of the box fuse, i can t figure out which fuse is for what exactly, i am not sure i found the one for the position light....
Thanx for your help
post #5 of (permalink) Old 06-19-2003, 08:11 AM
i can take pics of mine this weeekend if that helps ive got it pretty much all pulled apart for the wiring swap.. let me knwo if that will help ya
payton
payton is offline
post #6 of (permalink) Old 06-19-2003, 09:25 AM
FrenchJeeper
Well, i should be able to fix it by then. I ve found the position light problem already. The last thing is the gauges lights that are blowing my fuse. I put the block of gauges away and it stll do the same, i keep on looking, if you have any idea.....
Thanx
post #7 of (permalink) Old 06-19-2003, 09:31 AM
sounds like uve got a short or are dead groundong chase the wires from ur lights down to the block i bet there grounding out sum place.. just as in my daily driver
lil honda when i hit the brakes the door ajar light comes on
ive got a wire that hangs a lil low and comes in contact from time 2 time..
payton is offline
post #8 of (permalink) Old 06-19-2003, 10:27 AM
FrenchJeeper
Well, can it be a defective gauge light dimmer module??? If i put it an the low side it is OK but as soon as i turn it up it blows the fuse!!!... I d like to test the circuit with out using it but i have no idea which wire go where (i have four...)
Thanx
post #9 of (permalink) Old 06-19-2003, 10:49 AM
1. Well, it may or may not be a dead short.
2. The Orange Black wire goes to the illumination bulbs.
3. It get's it's voltage from the 5 amp fuse,
4. Which gets it's voltage from the Pink/Orange Wire
5. The Pink Orange wire's voltage comes from the Panel Lamp Dimmer Switch Assembly.
6. So, if that 5 amp fuse is blowing,
7. The problem is somewhere in the gauges.
8. I'd suspect a pinched wire leading to one of the bulbs.
9. Start physically tracing that orange black wire,
10. Follow it to EACH of the bulbs and sockets.
11. You should find the problem in no time at all.
post #10 of (permalink) Old 06-20-2003, 05:05 AM
FrenchJeeper
Grrrr, i found it and i am PISSED!!!!... A couple months ago my friends bought me a real nice CD player (Kenwood PSW 9524) for the Jeep. Since i didn't want to mess with it i had it installed by a pro.
Well, the guy didn't connect it coorectly, it worked with the gauge light fuse off but as soon as i put one in it blows. it seems like the orange/black wire acted like a - with out the fuse and that is where he plugged the radio mass!!!!!...
Well, now it should be fixed soon so, well, as long as the radio didn't burn it is alright....
Thanx for your help
