fuel gauge what ohm rating? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-16-2003, 09:31 PM Thread Starter
Hi I am going to be buying an autometer fuel gauge from summit for my 88 jeep wrangler. I was just wondering what ohm rating i will need to get it for. thanks Mike
pbytrailz is offline
post #2 of (permalink) Old 06-16-2003, 09:53 PM
Swansonoldcj
Re: fuel gauge what ohm rating?
I don't have the specs in front of me, but I've got a gauge tester at work that simulates required resitance from sending units and almost all of the required ohm range specs from the senders, so I'll get back to you tomorrow. Should not be a major dilema to get the right specs!!! [img]images/graemlins/40BEER.gif[/img] gas.
post #3 of (permalink) Old 06-16-2003, 10:19 PM
Aaron871's Avatar
Thread
Aaron871 is offline
post #4 of (permalink) Old 06-16-2003, 11:30 PM Thread Starter
better yet I am now thinking of using the stock cj speedo and the fuel gauge in that. is this possible to set up? the autometer gauges are to expensive. Mike
post #5 of (permalink) Old 06-17-2003, 02:45 PM
JEEPININMEXICO's Avatar
Rip out the stock dash and put in a CJ dash. I brazed in all of the nuts and added a couple extra to support the dash better.
Use the CJ wiring on the dash and splice it to the YJ wires. You will come up with a couple extra switches to use for lots of things.
JEEPININMEXICO is offline
post #6 of (permalink) Old 06-17-2003, 08:44 PM Thread Starter
actually I am doing a custom dash that will be much nicer.
I have it all planed out minus the fuel gauge cause I cant find the ohm specs for a stock yj sender.
Mike
post #7 of (permalink) Old 06-17-2003, 09:21 PM
1. Empty = 73 ohms
2. Half = 23 ohms
3. Full = 10 ohms
Or...
post #8 of (permalink) Old 06-17-2003, 09:25 PM
Swansonoldcj
I said I would get
the sender specs, and here they are!!!!!!!!!!!!!!!!!!!!!!!!!!! empty 1 0hm half 44ohms full 88 ohms these are the sender specs, match the gauge to this. good luck... gas. [img]images/graemlins/40BEER.gif[/img]
post #9 of (permalink) Old 06-17-2003, 09:38 PM
Swansonoldcj
The specs I just posted are from the 2003 version of alldata for testing the gauges response. But this is all really irelivent, cause a phone call to summit will get a gauge matched to the o.e. sender! gas. [img]images/graemlins/40BEER.gif[/img]
post #10 of (permalink) Old 06-17-2003, 09:38 PM Thread Starter
thanks for your time. that is the same thing I found out. that means it is a 0 to 90 ohm gauge the same as gm.
leve those specs are for a cj sender.
the only reason i was confused was this website
http://www.off-road.com/jeep/swb/articles/dash.htm
has the yj specs backwards. I figured this out after i noticed summit had no such gauge.
thanks Mike
