4lo-- 2hi-- 4hi- Questions - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-20-2003, 07:18 PM
I have been running the jeep with the 4wd shifter in neutral, but I was skimming the owner's manual and it said something about riding in 2hi. where should I keep the shifter and when would I use 2hi? help is always appreciated.
post #2 of (permalink) Old 04-20-2003, 07:28 PM
Carpal \'Tunnel
knifeboy2's Avatar
Re: 4lo-- 2hi-- 4hi- Questions
If you've been driving with your transcer case shifter in neutral, then you haven't been going very far unless you've been rolling downhill. In otherwords if your tcase is in neutral your tranny might as well be in neutral. So you've either been in 2Hi or 4Hi. You would use 2Hi on all roads. Only your rear tires are turning under power then. In 4Hi all tires are turning IF your hubs are locked. If you unlock your hubs then you are turning your front driveshaft but the power isn't being put to your tires.
So to answer your question directly, keep the shifter in 2Hi and your hubs onlocked when on pavement.
knifeboy2 is offline
post #3 of (permalink) Old 04-20-2003, 09:28 PM
the transfer case shifter moves freely, only when I pull it down or up the 4wd light comes on, it is an automatic does this make a difference
post #4 of (permalink) Old 04-21-2003, 06:03 PM
check linkages.... "u have somtin wong"... [img]images/graemlins/thud.gif[/img]
desertbuzz is offline
