how to tell a bad tps? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-19-2003, 07:53 PM Thread Starter
Pog
I have a problem with my 98 4.0 when I hit the gas hard under load it cuts out but I let off the throttle and it is fine so I am guessing a bad tps it is also running rich black tail pipe/// Anyone have any ideas?? Also can someone refer a site for getting the codes out I heard 3 cycles of the ignition but it never worked anyways I will be back later tonight.///. thanks James
Pog is offline
post #2 of (permalink) Old 04-19-2003, 10:05 PM
FuriousGeorge
Re: how to tell a bad tps?
sounds like your fuel pump is going. theres a gauge u can put on your fuel line and see what the pressure is(if its in specs) if it is running rich, sounds like an oxygen sensor
post #3 of (permalink) Old 04-19-2003, 10:15 PM
Official Curmudgeon
CJ7Taz's Avatar
I don't have any experience with the 4.0, mine is with the sbc TPI but they should works similar.
You should be able to measure the voltage from the tps with a high impedance voltmeter, digital would be best.
To get the codes, you could always take it to Autozone, they do a free error code scan
If the 4.0 works like the GM, it could be a lot of things causing the problem. At WOT, the GMs drop out of closed loop and into open loop for power. Depending on how rich you have been running and for how long, you may have ruined the O2 sensor and not be going closed loop anyway.
CJ7Taz is offline
post #4 of (permalink) Old 04-20-2003, 12:51 AM Thread Starter
Pog
Thanks for the response guys I will change the o2 I have a spare kickin round here in one of my many mopar boxes.... I will try it first..
Pog is offline
